Faulty Ignition
  • Wingman1962
2 years 2 months ago #25589 by Wingman1962
Faulty Ignition was created by Wingman1962
Need some advice.... Was planning to run my DA50 tomorrow but after a check over there seems to be no spark at the plug or plug cap. The battery is good and i have tried a different one and there is power going in to the ignition box. How can i test the unit to find out if its dead or if the plug lead is no good?. The previous owner said it was ok but he could say anything.
Any ideas on how to test it would be good. Thanks John
2 years 2 months ago #25590 by kevinross
Replied by kevinross on topic Faulty Ignition
try the RCexel ignition tester
I have one if you want to try it - call me on 07740 642832
2 years 2 months ago - 2 years 2 months ago #25591 by JonTappin
Replied by JonTappin on topic Faulty Ignition
It might be worth just trying to run it John. I went through this with a DA120 a few years ago, couldn't detect a spark at all testing it with the plugs out, but when I actually tried running it, it was fine.
Not saying you haven't got a faulty ignition, but just try it.
Last edit: 2 years 2 months ago by JonTappin.
2 years 2 months ago - 2 years 2 months ago #25592 by JRI
Replied by JRI on topic Faulty Ignition
I have one too, I find it invaluable as my RCexel ignitions do tend to break down over time - I live near Wimborne if Kevin is a bit of a trek for you!
The tester takes the place of the hall effect sensor and the rotary dial takes it from 0 rpm up to about 12K. I have found that the ignition units or possibly the HT lead often tend to fail at certain rev bands causing erratic operation of the engine and consequential random jet adjustments to try and compensate.
Last edit: 2 years 2 months ago by JRI.
2 years 2 months ago - 2 years 2 months ago #25593 by Phil Ford
Replied by Phil Ford on topic Faulty Ignition
Been there John. My relatively new GP38. One day failed to fire at all. Re-kitted carb as it appeared initially no fuel. Kevin checked crankcase, carb again. Nothing. Chris M had it over his place and I supplied him with 2 spare DLE ign units. Both worked and engine ran fine. Up the field it would not start. :angry: Chris took it back again. Bypassed the ignition switch - it ran. Faulty or erratic Rxel switch!
Last edit: 2 years 2 months ago by Phil Ford.
2 years 2 months ago #25595 by kevinross
Ive never had a faulty Rcxel ignition switch but guess its just a matter of time. However ive discovered Jeti offer an alternative product - twice the price but hopefully more reliable.
www.jetiuk.co.uk/index.php?main_page=pro...info&products_id=524
