Epoxy Glass Sheet
5 years 2 months ago #19059 by DaveBright
Replied by DaveBright on topic Epoxy Glass Sheet
It does work. I used cling film over blue foam to make the carbon retract blisters for my venom wing.
5 years 2 months ago #19062 by MikeSeale
Replied by MikeSeale on topic Epoxy Glass Sheet
An alternative to using cling film is baking paper. I made glass tubes for my Orcrist by wrapping baking paper around the carbon wing joiner. After wrapping it with glass I put heat shrink over the mess and once cured the tube came off the rod easily and the surface finish was smooth after the hear shrink was removed.
The following user(s) said Thank You: Phil Ford, John Bannister
Time to create page: 0.225 seconds
