Problems with my Plane - Riot Max Thrust
  • Alfie
17 Nov 2013 11:07 #640 by Alfie
Morning
Last weekend the plane lost engine power after a few minutes in the air. The trainer took over and the plane landed with no damage. Thank you.
As the batteries were working, was told to investigate the electrical connections, electric motor and the speed controller.
Have now got the motor running again. But the motor is noisy, seems very clunky when rotating it by hand and does not work all the time.
Based on the above, can I assume that the motor is the problem or do I have to look for another problem?
Thank you for your support.
Alfie
17 Nov 2013 16:47 #641 by Phil Ford
Replied by Phil Ford on topic Problems with my Plane - Riot Max Thrust
Alfie, looks like you followed my advice as per PM. If motor feels "clunky" to rotate I would suggest that a magnet has come loose. Other than stripping down the motor and checking security of all magnets and re-glueing where necessary I would suggest replacing motor.
Speaking to Kevin yesterday he said that the receiver was still being powered and connections appeared good.
Replacement can be found here www.centuryuk.com/Spares/Aeroplane-Spare...ss-Motor-%28850kv%29
Order early enough in mornings and get next day delivery!
  • David Seaman
18 Nov 2013 22:19 #643 by David Seaman
Replied by David Seaman on topic Problems with my Plane - Riot Max Thrust
Ordered! Thanks.
19 Nov 2013 10:36 #645 by Phil Ford
Keep me posted. If the motor runs in the wrong direction after connecting up, just swap any two motor wires to ESC
  • Alfie
23 Nov 2013 13:36 #676 by Alfie
Replied by Alfie on topic Problems with my Plane - Riot Max Thrust
Hi Phil
New motor. Same problem.
Thank you for notes on how to get the bits out. Now removed and sending back to Century to test and hopefully get replacements under warranty.
Speak soon.
  • tommy
23 Nov 2013 18:07 #678 by tommy
Replied by tommy on topic Problems with my Plane - Riot Max Thrust
Hi Alfie
Sometimes you can have a motor which tries to turn in both directions very slowly and very jerky. This is usually caused by a dodgy solder joint in one of the 3 connection wires between ESC and motor. test these if you can and resolder your 3 bullets on ESC. It cant be the motor because it's new. Secondly, double check lipo voltage, could be too low for the ESC/motor to work properly or cell numbers to low. Thirdly, try resetting ESC by putting throttle in full position then switch ESC on, wait for beeps then throttle to fully down and wait for more confirmation beeps, switch off then on again.
Before you bought new motor I would have gone with Phil on a loose magnet.
Only other point I can think of is if you have fixed your motor with screws through the motor body at one end which are too long and have fouled the wire turns, I've had this before now.
Tom
  • Alfie
23 Nov 2013 20:56 #681 by Alfie
Will try what you have suggested. If no joy, in the post back to the manufacturer on Monday.
Shame because tomorrow looks like a good to day to fly.
Thanks
23 Nov 2013 21:58 #684 by MikeSeale
Replied by MikeSeale on topic Problems with my Plane - Riot Max Thrust
If you want to pop over to Verwood on your way to Cashmoor tomorrow morning I can check your motor(s) using another ESC. Can also check the soldering and if that is your problem can send you on your way all fixed up.
  • David Seaman
23 Nov 2013 22:51 #685 by David Seaman
Evening Mike
What a star. Thank you.
What time would be convenient? Say any time after 10.
Address?
23 Nov 2013 22:57 #686 by MikeSeale
Any time after 10 would be fine.
58 Howe Lane
BH31 6JF
Number not clear on the gate post but look for black Peugeot on the drive
01202 829640 if you get lost
