LiPo - Cell Voltages
  • 4Pedalsfly
25 Oct 2017 22:57 #14394 by 4Pedalsfly
LiPo - Cell Voltages was created by 4Pedalsfly
I would welcome opinions on following:
Turnigy 3S - LiPo 3,300 mAh had little use and stored at 3.85V per cell when not in regular use
and always balanced charged.
Despite several attempts at Balance Charging it records cell voltages of 4.20 , 4.13 & 4.20.
Decision to be made, bin job or use ?
Thanks
25 Oct 2017 23:29 #14395 by MikeSeale
Replied by MikeSeale on topic LiPo - Cell Voltages
Since you've charged it you might as well use it. After the flight check voltages again to see whether you're right to be worried.
26 Oct 2017 07:38 #14396 by kevinross
Replied by kevinross on topic LiPo - Cell Voltages
4Pedalsfly wrote: I would welcome opinions on following:
Thanks
In addition to reduced cell voltage, you verify a cell has deteriorated by checking its internal resistance. Many modern chargers have this capability. A new cell should be ITRO 2/3 milli ohms and a cell will continue to work well up to 10 m/ohms. You will notice a significant performance drop > 20m/ohms
26 Oct 2017 08:48 #14397 by Phil Ford
Replied by Phil Ford on topic LiPo - Cell Voltages
I can check your internal resistance Colin with my charger Colin.
If resistance is within reason keep using it and get as much use out of it as possible. ;)
26 Oct 2017 09:02 #14398 by Brian
Replied by Brian on topic LiPo - Cell Voltages
Thanks Kevin, I didn't know about internal resistance and measuring it. Wish I'd known before, I've just taken four LiPos to the tip!
26 Oct 2017 19:46 #14405 by Phil Ford
I checked Colins lipo and cell 2 was at 12 meghom with voltage 1 volt down. Bin job like my two 6 cell lipos for the Beast.:(
27 Oct 2017 08:56 #14407 by JRI
Replied by JRI on topic LiPo - Cell Voltages
PhilF51 wrote: I checked Colins lipo and cell 2 was at 12 meghom with voltage 1 volt down. Bin job like my two 6 cell lipos for the Beast.:(
12 Megohm is as near as dammit open circuit. Sometimes the balance wires fall out of their jst-xh connector pins and the repair is just to fit a new pin or connector.
The battery would have no voltage atall on the main connector if the cell was really open circuit!
I suspect there is nothing wrong with the LiPO except for a broken balance connector or one of the balance wires itself is broken.
27 Oct 2017 11:58 #14408 by Phil Ford
in the case of the Beast Lipos John they had ballooned for some time, but squeezed as much life out of them as possible and I knew I had duffed them earlier for reasons I won't go into here. In Colin's case there was the voltage difference and mid cell high resistance. He had said it was no longer performing as expected.
I had to bite the bullet and buy two more 6 cell 60C Lipos. Tried the new one yesterday on the Beast bipe. Now it's a :) performer!
27 Oct 2017 12:24 #14411 by MikeSeale
JRI, I think Phil has his Mohm and mohm mixed up.
27 Oct 2017 12:37 #14412 by Phil Ford
MikeSeale wrote: JRI, I think Phil has his Mohm and mohm mixed up.
:lol: Yep! meant My Mum.
Time to create page: 0.447 seconds
