Motor Squealing
  • AlanF
22 Dec 2017 20:57 #15094 by AlanF
Motor Squealing was created by AlanF
Flying the Demonstrator today, pulling out of a failing hover and giving it a handful of throttle, I noticed a loud squealing noise coming from the motor. It sounded like a failing bearing but it wasn't that. I'm familiar with the general sound of an electric motor, including the rasping noise of a cavitating prop but this one is new to me. It was brief and only happened once in the four flights I had today. It sounded nasty but does anyone know what causes it and is it harmful?
22 Dec 2017 21:52 #15095 by MikeSeale
Replied by MikeSeale on topic Motor Squealing
You closed the throttle on the way down and when you opened the throttle quickly the ESC/motor went into a cycle of confusion. The solution is to set the bottom end so that the motor does not stop, then when you open the throttle the esc and motor know which way to spin.
22 Dec 2017 21:54 #15096 by kevinross
Replied by kevinross on topic Motor Squealing
One possibility is loose magnets inside the outer casing
22 Dec 2017 21:55 #15097 by MikeSeale
Go back to the thread last week when I said...
At start-up, a brushless controller sends a pulse to the motor and the motor will either spin clockwise or anticlockwise. The controller senses the back emf and determines if the motor is spinning the correct way. It will then send another pulse to keep it spinning the same way or the opposite pulse as necessary. In flight, a windmilling prop can confuse this sequence and the controller/motor combination squeals and shuts down. This is more evident with some controllers and the cheaper ones seems to suffer more. Keeping the motor ticking over at low rpm avoids this problem.
  • AlanF
22 Dec 2017 21:56 #15098 by AlanF
Replied by AlanF on topic Motor Squealing
kevinross wrote: One possibility is loose magnets inside the outer casing
This I don't want to hear. :(
22 Dec 2017 21:58 #15099 by 4Pedalsfly
Replied by 4Pedalsfly on topic Motor Squealing
Hi Alan - It may be worth checking that the grubscrews retaining the shaft are tight.
Did you get any flying in after we left ?
  • AlanF
22 Dec 2017 22:10 #15100 by AlanF
MikeSeale wrote: Go back to the thread last week when I said...
Thanks for that Mike but, this is with Idle up in force, to the extent that I have to kill the idle up to land within the field when there is no headwind. It's possible that the plane is dropping sufficiently quickly to stall the motor, in which case it's perhaps a case of "well don't do it then".
A quick google suggests that motor timing might be an issue but as it's only happened once I'm reluctant to mess with this.
From what I'm led to believe Extreme Flight don't do cheap!
  • AlanF
22 Dec 2017 22:19 #15101 by AlanF
4Pedalsfly wrote: Hi Alan - It may be worth checking that the grubscrews retaining the shaft are tight.
Ah, Thanks Colin, I hadn't thought of that. The spinner and prop positions are marked on the spinner backplate and these haven't moved but I haven't checked anything else.
I got a few more flights in after you left, but the promised sun never appeared and it started raining quite heavily at about 3 ish so I gave up.
  • AlanF
22 Dec 2017 22:29 #15102 by AlanF
Quick edit: The real question I suppose is: is it harmful? The rest I can live with.
22 Dec 2017 22:44 #15103 by MikeSeale
Okay. And you say the prop has not moved so it must be tight?
In that case check the timing and possibly the PMW frequency. The video that Chris posted shows that it is not difficult to change a setting...you just have to be patient and listen to all those beeps.
