Exhaust gasket material
15 Mar 2015 10:58 #3961 by DaveBright
Exhaust gasket material was created by DaveBright
Where's the best place to obtain exhaust gasket material. On looking into the cowl of my Sbach it would very much seem that the gasket has gone.
There seem to be a few types available and for different applications.....
It was suggested to me yesterday that cereal box cardboard does the job if cyano is used to seal the permeable side....? - will give this a go initially as need to get the sbach flying whilst the sukhoi heart is in at the menders....
Cheers
15 Mar 2015 11:16 #3962 by Phil Ford
Replied by Phil Ford on topic Exhaust gasket material
DaveBright wrote: It was suggested to me yesterday that cereal box cardboard does the job if cyano is used to seal the permeable side....?
Cheers
I do this for years on cars, carb , thermostat housings,etc, etc. I used to use Kellogs cornflakes card, printed on one side and waxed the other, although card packaging has changed over the years, hence the suggestion of thin CA to seal it. Or, try your local garage and see if you can scrounge a bit of gasket sheet and cut your own out.
Best of luck Dave and hope you get sorted with the Sukhoi quickly and not have to dig deep into pockets.
  • FrankRobinson
15 Mar 2015 11:39 #3963 by FrankRobinson
Replied by FrankRobinson on topic Exhaust gasket material
Dave, The exhaust temperature on high loads will be in the region of 500 to 700 degrees C, Cardboard is not any use for this you need a graphited impregnated material or soft alli even copper for high temps and loads, some exhaust use face to face joints with graphite grease because it is very hard to have a material that takes up the expansion, come and see me
15 Mar 2015 11:48 #3964 by JonTappin
Replied by JonTappin on topic Exhaust gasket material
Dave
I have used a couple of layers of ali cut from a drinks can, soft ali as Frank has suggested above, seems to work ok. Cuts easily with some sharp scissors.
15 Mar 2015 16:39 #3965 by kevinross
Replied by kevinross on topic Exhaust gasket material
If its DA 50
www.probuild-uk.co.uk/dle50-dle55-exhaus...t.html?search=gasket
others available
I always add a smear of high temp silicone (from Halfords) or similar
15 Mar 2015 21:14 #3970 by DaveBright
Replied by DaveBright on topic Exhaust gasket material
Thanks for the suggestions guys.
  • chris.m
16 Mar 2015 21:38 #3972 by chris.m
Replied by chris.m on topic Exhaust gasket material
I can spare you some, think i made the one's on your suk!
16 Mar 2015 21:51 #3973 by DaveBright
Thanks Chris..... I made one this morning out of sheet brass. Will see how it holds up tomorrow. Also popped round to grandad Frank :) for some expert opinion on my 111's health. Thanks for the help Frank, much appreciated.
16 Mar 2015 22:08 #3975 by Chris73
Replied by Chris73 on topic Exhaust gasket material
So what's the verdict on the engine Dave??
16 Mar 2015 22:23 - 16 Mar 2015 22:24 #3976 by JonTappin
What was the verdict then?
Last edit: 16 Mar 2015 22:24 by JonTappin. Reason: Dammit, Chris beat me to it!
Time to create page: 0.323 seconds
