real flight 8
7 years 8 months ago #15601 by
real flight 8 was created by
I have just got real flight x wireless interface and could not connect my dx8 to the sim does any one have any ideas why this could be.
7 years 8 months ago - 7 years 8 months ago #15602 by Phil Ford
Replied by Phil Ford on topic real flight 8
Do you mean the Real flight is not finding the DX8?
Or not connecting?
You need to tell us what you have done so far.
In the meantime, I am assuming you are running Windows 10 on a PC.
When you plug in the interface lead into a USB port did the system say found new USB device?
Last edit: 7 years 8 months ago by Phil Ford.
7 years 8 months ago #15603 by
Replied by on topic real flight 8
I do run windows 10 and I'm not sew about it being found on a new usb device but the interface flashis red then turns of and is no light.
7 years 8 months ago #15604 by Phil Ford
Follow this link from Real Flight. There are a number of reasons so you need to work through them gradually.
www.realflight.com/support/kb/article.php?q=01-1022
7 years 8 months ago #15605 by
Hi Phil,
I am Jacob's dad.
What we have done is bought the wireless interface RF-X which Sussex Model Centre suggested. We have plugged it into the USB and attempted the binding process, but it did not work. The controller shows the orange light on which I believe means it is transmitting? On the wireless interface it has a red light which is flashing, if it successfully binds than it will go a solid red.
Any ideas?
KR's
Julian
7 years 8 months ago - 7 years 8 months ago #15606 by Phil Ford
Sorry, I should've read the post carefully. You are using a wireless interface ,not a hard wired lead. Not sure on this one but if the interface is transmitting then you need to go into the DX8 bind mode as if you were binding (pairing) a receiver.
Note: Interface is not compatible with version 6 or lower.
Oh, and ensure you are PPM mode on the Transmitter.
DX8 owners jump in here....
Edit: Have you selected from the Real flight menu Simulation (top left corner) and chose the transmitter you are using. That is a definitely a good start.
Time to create page: 0.243 seconds
