Tail Wheel Springs
01 Oct 2018 17:40 #17890 by Phil Ford
Tail Wheel Springs was created by Phil Ford
Surfed until my eyes were like an owls, big and expressionless. :blink: Where can I get some tail wheel springs from? The Pitts lost one on Saturday. Might be handy to have supply of them.;)
01 Oct 2018 18:18 #17891 by Chris73
Replied by Chris73 on topic Tail Wheel Springs
Good question, and when you find out please let the rest of us know
01 Oct 2018 18:23 #17892 by John Bannister
Replied by John Bannister on topic Tail Wheel Springs
What type of spring is it Phil
01 Oct 2018 18:35 #17893 by kevinross
Replied by kevinross on topic Tail Wheel Springs
Phil Ford wrote: Surfed until my eyes were like an owls, big and expressionless. :blink: Where can I get some tail wheel springs from? The Pitts lost one on Saturday. Might be handy to have supply of them.;)
I have a small selection !
01 Oct 2018 18:52 - 01 Oct 2018 19:22 #17896 by Phil Ford
Replied by Phil Ford on topic Tail Wheel Springs
We all know what they look like.;) Pretty standard springs on all the tail wheel items I have seen. There must be springs at a few pence each somewhere compared to buying new tail units every time . :(
Specs:
Total Length = 100mm
Spring Coil Length = 50mm
Spring Diameter = 3.55mm
Spring Wire gauge = 0.062mm
Don't ask me what tension though.
The springs pictured here. although my tail wheel is a bit more scale than the Miracle 120cc
I had considered this uk.rs-online.com/web/p/extension-springs/0821475/ and straighten out the coils each end to create free length of 100mm
Last edit: 01 Oct 2018 19:22 by Phil Ford.
01 Oct 2018 19:52 #17899 by John Bannister
Phil just checked I have a assortment of springs that should fit the bill instead of straightening the end you could make a wire closed hooks to extend I mi,ght be able to make springs to your pattern from piano wire. I think your wire gauge is wrong were back on microns
01 Oct 2018 20:31 #17900 by JRI
Replied by JRI on topic Tail Wheel Springs
I possess a spring making tool - if you have the piano wire of the right diameter I can knock one up for you.
01 Oct 2018 22:54 - 01 Oct 2018 22:55 #17902 by Phil Ford
Cheers. Might need more than one JRI judging by earlier responses. I'll see what i can find in the way of piano wire.
joneb wrote: I think your wire gauge is wrong were back on microns
I don't do Microns. I think your getting confused with Grommet. :lol:
Last edit: 01 Oct 2018 22:55 by Phil Ford.
01 Oct 2018 23:34 #17903 by DavidTappin
Replied by DavidTappin on topic Tail Wheel Springs
Phil, if you fancy starting a collection take a look at:
www.johnrichardssurplus.co.uk/hilka-150-...rtment-79551650.html
Regards,
David
02 Oct 2018 09:36 #17909 by John Bannister
which is 2.44094488188976 thousandths of a inch or about the thickness of a hair
Time to create page: 0.365 seconds
