Airworld Hawk 1:4.5
12 Jul 2015 18:27 #5113 by DaveBright
Airworld Hawk 1:4.5 was created by DaveBright
Right.... I've had this chap now for nearly a year, it's about time I cracked on and got it ready to fly.
I had to wait until April to purchase the turbine (Wren160K) and have been accumulating all the various bits and bobs needed for the model's slight refurb.
The following needed doing:
  • Reinstall the nose gear doors and install new arms and associated servos (DONE). The doors also need respraying as previous owner landed nose wheel up on Tarmac.
  • make and hinge new third nose door (DONE)
  • source and install nose light to run off 11.1v (DONE)
  • reinstallation of all electronics
  • source pilot (DONE - homemade)
  • find an easy way to hinge and operate third outer main gear door (DONE)
  • source (DONE) and fit real strobe units
  • replace all wing servo extensions as previous owner had soldered multiple extensions (DONE)
  • replace tail and main gear door servos servos (DONE)
  • respray centreline pod
  • fit Powerbox SRS
  • decide on gyro (cortex or igyro
  • remove all traces of silicone! And make cockpit tub removable (DONE)
  • source pitot tube (DONE)
  • find suitable site for (re)maiden flight
Whilst I appreciate not all these points are necessary to flight, I would like it all sorted before hand.
I now have the Hawk stored back at my parents. Space has been cleared in the workshop (suk/sbach stored on wall brackets allowing room to work in this beasty)
I'm now happy to report that when time allows, I am pushing on an progressing with the above list! Photos to follow.......
12 Jul 2015 18:32 - 12 Jul 2015 18:33 #5114 by DaveBright
Replied by DaveBright on topic Airworld Hawk 1:4.5
Few more..
Last edit: 12 Jul 2015 18:33 by DaveBright.
12 Jul 2015 18:48 #5116 by JonTappin
Replied by JonTappin on topic Airworld Hawk 1:4.5
Good work so far Dave, definitely worth redoing the electronics install, looks like the proverbial nest for rats!!
12 Jul 2015 18:52 #5117 by JonTappin
Can't help thinking you should keep the pilot like this. Naked moustached man, very you :)
12 Jul 2015 18:59 #5118 by DaveBright
JonTappin wrote: Naked moustached man
:lol:
12 Jul 2015 19:14 - 12 Jul 2015 19:16 #5119 by Phil Ford
Replied by Phil Ford on topic Airworld Hawk 1:4.5
JonTappin wrote: Good work so far Dave, definitely worth redoing the electronics install, looks like the proverbial nest for rats!!
I was thinking the same! :lol: Now! Which wire goes where? Image 6, that the old Hawk to compare with the newbie?
So your excuses will be: staying home to work on Hawk? ;)
A bit of a biggy project you've took on there. Still, should keep you out of trouble for some time!
Last edit: 12 Jul 2015 19:16 by Phil Ford.
12 Jul 2015 19:46 #5121 by flyingpete
Replied by flyingpete on topic Airworld Hawk 1:4.5
Really nice Dave ;)
17 Jul 2015 18:09 #5158 by AlanF
Replied by AlanF on topic Airworld Hawk 1:4.5
Looks good Dave, is this a candidate for a flight from Cashmoor or is it tarmac runway only?
17 Jul 2015 19:06 #5160 by DaveBright
I would ideally like to do the first flights from Tarmac but no, this one will be fine from Cashmoor
17 Jul 2015 19:50 #5161 by flyingpete
When do you reckon Dave? :-)
Time to create page: 0.385 seconds
