BAe Hawk slope soarer by PJ Models
30 Dec 2017 18:33 #15178 by Chris001
BAe Hawk slope soarer by PJ Models was created by Chris001
I've made a start on this Hawk sloper, I do not know when the kit was made, but I'm guessing early 80's.
The fuselage, wings, elevator halves and fin are all veneered foam, and just required a bit of re-gluing around the edges and they should be fine now, I will need to make a new fin however, as the one supplied is badly warped. And at some point find or make a canopy which, I think, was the only thing missing.
It is designed to be a two channel glider, the ailerons to be driven by a single servo and torque rods. But is that the best way in this day and age? I figure I have three options:
  • go with it as designed
  • put two aileron servos in the fuselage to power the torque rods
  • put two servos in the wing. - I'm guessing they would have to go in the top of the wing otherwise I'd be replacing them after every landing.
  • Any thoughts?
    30 Dec 2017 18:53 #15179 by 4Pedalsfly
    Replied by 4Pedalsfly on topic BAe Hawk slope soarer by PJ Models
    Chris - Unusual project for you, I think of you building built up structures, I would go for 1 servo in each wing
    If there is enough thickness in the wing you may getaway with having the servos under the wing, otherwise put them
    in the top per Zagi style.
    Look forward to seeing some pics.
    30 Dec 2017 19:51 #15181 by Chris001
    Replied by Chris001 on topic BAe Hawk slope soarer by PJ Models
    Thanks Colin,
    Two servos would seem to make sense these days.
    It's fair to say I feel more confident with planks of balsa but I was also intrigued by the kit that Phil Coupe was trying to find a good home for, I hope I am that good home!
    30 Dec 2017 20:18 #15182 by MikeSeale
    Replied by MikeSeale on topic BAe Hawk slope soarer by PJ Models
    With mini servos you'll only have the linkage sticking out and will not need to replace each time assuming metal gears. My Algebra is basically a low wing model and has 4 servo arms poking out and I have not stripped a gear yet.
    30 Dec 2017 20:19 #15183 by MikeSeale
    The kit looks in better shape that I was expecting.. or do the photos hide a lot of imperfections?
    30 Dec 2017 21:04 #15184 by Chris001
    Thanks Mike,
    It's not in that bad a condition, and looks a lot better now the veneer isn't hanging off, I think the fin and canopy are the only things not to survive storage.
    30 Dec 2017 21:38 #15185 by MikeSeale
    The fin will be easy to replace. A few symmetrical ribs and 1/16 sheeting to keep it light at the back in order to avoid having to add too much nose weight.
    The Hawk is such a popular subject that it must be possible to buy one somewhere.
    30 Dec 2017 22:42 #15187 by 4Pedalsfly
    Chris - Worth a look at Vortex Vacforms ( Leicester ) they have a extensive range of canopies & possibly
    made them for P.J. Models.
    Hope this helps.
    30 Dec 2017 23:01 #15188 by Chris001
    Thanks Colin, You're right they have a Hawk Canopy that looks like it might be a perfect fit.
    Mike, I half toyed with the idea of just making the fin one thickness, but it's got to be shaped.
    31 Dec 2017 08:38 #15190 by DaveBright
    Replied by DaveBright on topic BAe Hawk slope soarer by PJ Models
    Looking forward to seeing this progress. I have an old PMC/LMC Hawk kit waiting to do something with one day. Originally for IC prop but sloped might be a quicker alternative! One day.... I’ll await inspiration from your quick build thread Chris :)
