Modified Hacker - "HotWing 750"
  • 4Pedalsfly
6 years 5 months ago #18798 by 4Pedalsfly
Modified Hacker - "HotWing 750" was created by 4Pedalsfly
This was part of one of those "Job Lots" which often tempts one.
The guy had started the model, fitted the motor mount, servos, control surfaces & carved out the cavities
in the wing for the e.s.c. , receiver & battery.
It quickly became apparent that with the motor I intended using it would require a lot of lead up front
to get the correct C of G.
So the decision was made to fill in the cavities and add a "fuselage" with a shortish nose to balance without
any lead.
See 3 pics below - more pics to follow.
  • 4Pedalsfly
6 years 5 months ago #18799 by 4Pedalsfly
Replied by 4Pedalsfly on topic Modified Hacker - "HotWing 750"
More pics showing construction detail.
6 years 5 months ago #18800 by Phil Ford
Replied by Phil Ford on topic Modified Hacker - "HotWing 750"
Nice job Colin! Do you think you will be able to catch my Superwing though? ;)
  • 4Pedalsfly
6 years 5 months ago #18801 by 4Pedalsfly
Now the interesting bit - maiden flight - 4th December 2018.
After some rapid trim clicking all was well.
Thanks to Simon Osborne - great launch, Tim Sullings - in-flight pictures.
Model Data -
Motor - HK - BL 2212/6 , 2,200kv, : ESC -BRC Hobbies 33A : Prop APC 7x3 : Battery - 3s - 1,500 LiPo. :
Wingspan 750mm : Weight - 366g ( 14 ozs ) : Power 310 Watts : Watts per Ib = 350.0 , Wing Loading 6.8 ozs per sq ft.
Apologies for mixture of units.
The model climbs vertically and on full throttle in level flight I can just about keep up with her, with the
low wing loading landing is at a slow walking pace.
Conclusion - Great little one piece fun model, the extra weight not being a problem and a benefit for flying
at Cashmoor.
Colin.A
6 years 5 months ago #18803 by DaveBright
Replied by DaveBright on topic Modified Hacker - "HotWing 750"
Phil Ford wrote: Nice job Colin! Do you think you will be able to catch my Superwing though? ;)
Highly likely :-)
  • 4Pedalsfly
6 years 5 months ago #18805 by 4Pedalsfly
Phil - You wrote the above before I posted the models data. - 350 Watts per pound !!!!
You are definitely on - looking forward to the challenge - watch out for my roll call posting.
Time to create page: 0.295 seconds
