2nd Elevator Servo for 7 Channel Receiver. Futaba
  • Simon O
01 Jul 2018 19:34 #17009 by Simon O
I think I know the answer but I will ask if anyone has an idea. I have a 7 ch Orange receiver/gyro to put in a model that has 2 elevator servos. On Futaba, ch8 is the 2nd elevator channel. I don't have an 8th and I cannot fathom how you drive 2 servos. Tried a 'Y' lead, just means elevators go in different directions. I guess I will have to have a separate gyro unit running through a Futaba 8ch receiver. Maybe you have a better solution, I hope so!
Simon O
01 Jul 2018 20:24 #17010 by 4Pedalsfly
Replied by 4Pedalsfly on topic 2nd Elevator Servo for 7 Channel Receiver. Futaba
Simon - Couple of ideas for you, using existing elevator set up & "Y" lead.
1 - Change linkages / horn position on 1 servo so they move in the same direction.
2 - Fit electronic servo reverser to 1 servo.
Trust this helps.
  • Simon O
01 Jul 2018 20:27 #17012 by Simon O
Many thanks Colin. I will look at the possibilities
Simon
01 Jul 2018 20:47 - 01 Jul 2018 20:50 #17015 by JRI
Too late now Simon, but all you do with Futaba is make servo 5 (or any other spare channel you choose) a slave of servo 2 (programmed in the Tx) and it will happily track (or reverse) every elevator movement. I will show you or PM you the exact setup if you tell me which Tx model you have (it has been an available feature since the very first digital Tx futaba made), and every model I have has dual elevato servos.
Last edit: 01 Jul 2018 20:50 by JRI.
01 Jul 2018 21:10 #17017 by 4Pedalsfly
Hi John - I went the simple route.
I bow to your superior programming skills Mr Jet Jockey.
  • Simon O
01 Jul 2018 21:12 #17018 by Simon O
John, I would be very grateful to have the knowledge of how to do it. I have a t8j transmitter. The channels available are 5 & 7. The gyro is switched on 5 as per the receivers instructions.
Many thanks
Simon
02 Jul 2018 07:53 - 02 Jul 2018 08:01 #17020 by JRI
Programmable mix (page.65) - To setup channel 7 (AU1) to track channel 2 (ELE):
P.MIX-5
Master = ELE
SLAVE = AU1
TRIM = N/A
SWITCH = NULL
RATE = 100%
OFFSET = 0
if this works Ok you can use reverse, sub-trim, end-point functions, etc on AU1 (channel 7) to make sure evelator 2 accurately tracks elevator 1 as you desire. I don't know your transmitter but you may also need to set the TRIM value to track your elevator trim control too.
PS. Check VERY carefully that NO other control or switch has any affect on channel 7 other than the Elevator control and trim.!
Last edit: 02 Jul 2018 08:01 by JRI.
  • Simon O
02 Jul 2018 09:24 #17021 by Simon O
Many thanks John I will see what I can do!
Simon
02 Jul 2018 09:56 #17022 by John Bannister
Replied by John Bannister on topic 2nd Elevator Servo for 7 Channel Receiver. Futaba
Simon I think the way to go is with the Y lead if you try to do a mix when you switch the gyro on you will have one elevator controlled by the gyro and the other controlled by the transmitter which may be interesting. but not what you intend..
Also there is a known problem with the latest futaba software and non futabu rx's causing loss of signal when flying with other futabu users. Futabu answer is buy futabu.
  • Simon O
03 Jul 2018 13:40 - 03 Jul 2018 13:42 #17044 by Simon O
Hi John RI
Thank you for working out what I needed to do, works a treat and even better, no other switches or other controls affecting the elevator on 7 which is great. I have set up the gyro which is a really basic 3 axis unit. Only problem is I cannot seem to get the giro to work the ch 7 elevator servo. The control surface is unaffected whereas the elevator servo on ch2 reacts fine. I will keep studying the instructions!
Last edit: 03 Jul 2018 13:42 by Simon O.
