DSX 9 Gimbal
5 years 4 days ago - 5 years 4 days ago #23449 by Phil Ford
DSX 9 Gimbal was created by Phil Ford
Today I have noticed that when bringing the throttle down to low if I pulled a little too hard back it acts as throttle cut. In other words it going past the near end of the pot. Needs replacing and have contacted Mike at Model Radio. This may be some of the issues that I have had with throttling down on IC engines. Might be the end of life for this DSX9. :(
Last edit: 5 years 4 days ago by Phil Ford.
5 years 4 days ago #23450 by JRI
Replied by JRI on topic DSX 9 Gimbal
Most higher end transmitters have a stick calibration feature - have you checked your manual?
5 years 4 days ago #23451 by kevinross
Replied by kevinross on topic DSX 9 Gimbal
John Ireland wrote: Most higher end transmitters have a stick calibration feature - have you checked your manual?
Never seen anything in my DSX9 manual re stick calibration. Although it was the first JR unit to adopt DSM2 RF protocol, i think the firmware dates to pre 2010.
5 years 4 days ago #23452 by Brian
Replied by Brian on topic DSX 9 Gimbal
Can you find the Service Manual for the DSX9 Phil? Years ago I had problems with an early JR X-347, sorted it using the JR service manual, which gave instructions for a factory reset procedure.
5 years 4 days ago #23453 by Brian
www.rcheliwiki.com/JR_9XII_service_menu
Here's a link that mentions the DSX9 as well as the 9X11
5 years 3 days ago - 5 years 3 days ago #23454 by Brian
Phil, I just tried this routine on my DSX9 and I can get it to go to factory settings. It might solve your throttle prob.
Last edit: 5 years 3 days ago by Brian. Reason: .JPG file added
