Boring conversation
  • JRI
10 Apr 2019 08:34 #19269 by JRI
Boring conversation was created by JRI
I have a mini lathe which I use for turning up spacers and undercarriage bits, I also have an HSS drill set from 1mm to 6mm in 0.1 mm steps for making small holes. But I have found that I also need to drill slightly larger holes of non-standard sizes (e.g 6.4mm diameter for a wheel bearing on a 1/4" axle). Does anyone have any experience or recommendations for very small boring bars for carrying out this sort of work? Kevin?
10 Apr 2019 10:19 - 10 Apr 2019 10:47 #19270 by 4Pedalsfly
Replied by 4Pedalsfly on topic Boring conversation
John - Being a pre- metric man, you may wish to look around for Letter & Number Sized drills plus drills in 1/64 in increments
which may come in useful.
Letter "F" is .257in dia - just search on Letter & Number drill sizes and suppliers come up.
No doubt Kevin will come up with a less boring solution.
Last edit: 10 Apr 2019 10:47 by 4Pedalsfly.
10 Apr 2019 11:23 #19271 by kevinross
Replied by kevinross on topic Boring conversation
JRI wrote: I have a mini lathe which I use for turning up spacers and undercarriage bits, I also have an HSS drill set from 1mm to 6mm in 0.1 mm steps for making small holes. But I have found that I also need to drill slightly larger holes of non-standard sizes (e.g 6.4mm diameter for a wheel bearing on a 1/4" axle). Does anyone have any experience or recommendations for very small boring bars for carrying out this sort of work? Kevin?
please clarify - do you want boring bars because you drill wont accept larger sizes - in which case its possible to turn down the softer shanks of larger drills - provided the drill has sufficient head room
I use and find stepped drills invaluable and have found them in metric & Imperial
www.ebay.co.uk/itm/5-Pieces-HSS-Step-Lar...4:g:~nkAAOSwZJBX-0pI
The ones with a hex drive are best. the depth is limited but you could bore a prop or wheel from both sides - The next cutter automatically www.ebay.co.uk/itm/5-Pieces-HSS-Step-Lar...4:g:~nkAAOSwZJBX-0pI
  • JRI
10 Apr 2019 11:51 #19272 by JRI
Replied by JRI on topic Boring conversation
Hi Kevin, I have chucks and collets up to 14mm so no problem there. My wish is to be able to turn holes in things mounted in my lathe chuck (like ally wheels) to a few thou' accuracy where I don't have a drill that suits. I could buy a 6 to 10mm drill set in 0.1 increments but it would cost around £85 and 90% of the drills will never be used, and the chances are my next job will need 10.3mm !
Also some existing bores on items that I am working on are slightly off-centre or gone eccentric so a drill bit tends to wobble rather than follow the true centre!
10 Apr 2019 14:24 - 10 Apr 2019 19:21 #19273 by kevinross
JRI wrote: Hi Kevin, I have chucks and collets up to 14mm so no problem there. My wish is to be able to turn holes in things mounted in my lathe chuck (like ally wheels) to a few thou' accuracy where I don't have a drill that suits. I could buy a 6 to 10mm drill set in 0.1 increments but it would cost around £85 and 90% of the drills will never be used, and the chances are my next job will need 10.3mm !
If you try to true up for example an off centre wheel bore, the boring bar would need to be so fine, it would tend to bend with the hole eccentricity so In that case i would use an end mill or slot drill in the tailstock chuck to create an centred bore then adjust the bore accuracy. You could search for small adjustable reamers
www.tracytools.com/1-4-9-32-adjustable-reamer?keyword=reamer
or make your own D bit from silver steel -
These are posh D bits - for a one off I would simply hacksaw and file the segment away. You could also make one with a pilot spigot to ensure accuracy
The following you tube offers more options for mini boring tools
Last edit: 10 Apr 2019 19:21 by kevinross.
11 Apr 2019 06:58 #19275 by John Bannister
Replied by John Bannister on topic Boring conversation
John Axminster power tools sell drills in increments of .1
www.axminster.co.uk/axminster-m2-ground-hss-drill-bits-ax22813
The D bit works fine just grind it to exactly 1/2 diameter drill out to 6mm and slow feed if you just want a couple of holes you might get away without hardening it.
  • JRI
12 Apr 2019 13:04 #19283 by JRI
The answer was to mount a 6mm dia milling cutter in an ER25 collet chuck on the tailstock. With the wheel clamped by the brake face using the outside jaws of a 3-jaw chuck on the lathe. Very slow feed and the hole was trued up quite nicely.
12 Apr 2019 16:50 #19284 by John Bannister
Surely if you use 6mm end mill you end up with a 6mm hole unless you offset the tailstock or it wasn't centered in the first place
12 Apr 2019 18:36 #19286 by DavidTappin
Replied by DavidTappin on topic Boring conversation
joneb pointed out that
He is quite right of course, to put it in perspective the tailstock would only need to be 2 thou’ out of line with the headstock for a 6mm milling cutter to produce a 6.1 mm hole with that set-up. Sorry about the mixed units but somehow 2 thou’ seems a lot less than 0.05 mm!
  • JRI
12 Apr 2019 20:51 #19287 by JRI
Quite right (both of you) what I suspect is that the original hole created using a 1/4" (6.35mm) drill wandered but the 6mm end mill took out the low point of the eccentricity maybe resulting in the far end of the hole being a couple of thou' larger than planned and not perfectly circular but sorted!
Time to create page: 0.484 seconds
