whats the difference
7 years 2 weeks ago #17810 by
whats the difference was created by
hello I was just wondering out of interest what is the difference between a 3 and 2 bladed propeller
7 years 2 weeks ago #17811 by MikeSeale
Replied by MikeSeale on topic whats the difference
Approximately 50% more blades on the 3-bladed prop
7 years 2 weeks ago #17812 by MikeSeale
A 2-bladed prop is usually a little bit more efficient than 3. It's also easier to manufacture which means it will be cheaper to buy. And it is easier to balance a 2-bladed prop.
A three bladed prop will be smaller in diameter compared to the 2-bladed prop it replaces. For example, 12x6 two bladed prop might give the same performance as an 11x6 three bladed prop. This smaller diameter means that the tips of the prop are moving at a slower speed. This reduced tip speed will make the 3-bladed prop quieter than the 2-bladed prop
7 years 2 weeks ago #17813 by MikeSeale
Advantages of 2 blades
Cheaper
More efficient
Easier to balance
Advantages of 3 blades
Quieter
7 years 2 weeks ago - 7 years 2 weeks ago #17814 by JonTappin
Replied by JonTappin on topic whats the difference
JacobWinfield12 wrote: hello I was just wondering out of interest what is the difference between a 3 and 2 bladed propeller
Although Mike has thoroughly answered your question :)
I will add that in simple terms, 2 blade props are more efficient than 3 blades, but 3 blades are quieter as the diameter is less and hence so is the tip speed
Edit- I posted this after Mike's first reply, now I see that he has answered in full, happily he has also given you the same answer but in more detail!
Last edit: 7 years 2 weeks ago by JonTappin.
7 years 2 weeks ago #17816 by
Replied by on topic whats the difference
thank you very much it makes more sense know :)
Time to create page: 0.522 seconds
