Fsky Taranis X9D Plus
01 Oct 2017 20:10 - 01 Oct 2017 20:11 #13922 by Phil Ford
Many thanks Chris. I think I see the bit I am overlooking. Yes i have used Companion 2 and also found you can drag an Input line down and then edit it to suit. I will have another play tomorrow. Companion 2.1.7 would not talk to Plus. Downloaded 2.1.9 and now it does. Now I can exit the bootloader properly.:)
I also think Stuart that your version is an early one because the Plus had some different coding.
Oi! What's all this formal greeting Mr Chris Wild......:lol:
Last edit: 01 Oct 2017 20:11 by Phil Ford.
  • Stuartmck
01 Oct 2017 20:20 #13924 by Stuartmck
Replied by Stuartmck on topic Fsky Taranis X9D Plus
Should have said I programme on the Tx. As far as I know, the solution is the same with later firmware.
Stuart
01 Oct 2017 20:26 #13925 by Chris001
Hi Phil,
Glad you managed to get Bootloader, OpenTX and Companion all to the right versions to talk happily with each other, I remember going round in circles the first time I did it and cannot remember the exact route I took to get it done. I'm on 2.19 so that makes like easier. I'm by no way an expert, but if I can help I will,
01 Oct 2017 20:35 #13927 by Chris001
Phil, have you seen the new RX for gliders... built in Vario for the same price as an X8R
www.t9hobbysport.com/frsky-g-rx8-receiver
02 Oct 2017 08:30 #13928 by Phil Ford
No I had not seen that. I will have to get one of them or maybe two (got two gliders);) Hi precision Vario was £19 on HK. X8R receivers £30.
02 Oct 2017 09:10 #13929 by Brian
Hi Phil, I tried to understand the Taranis video on YouTube unfortunately the video id 53 minutes and my attention span won't cope with that timescale. However, there was a load of stuff in RCM+E a short time ago. I don't know if this will help.
www.modelflying.co.uk/news/article/opent...-to-install-it/23076
I think I might end up using my old 35 Meg JR stuff.
02 Oct 2017 14:26 #13931 by Phil Ford
Brian, I have watched quite few of the videos, some are useful but some ramble on so much I lost attention too. I would much rather read the info (at my pace) along with decent images at each stage.
02 Oct 2017 15:48 - 02 Oct 2017 16:00 #13936 by Phil Ford
Written up the programming in Companion and wrote to TX. Used the Fox fuselage to check results (elevator & rudder). Compared to JR the rates % need to be lot lower than I expected. Although I have set elev and rudd to the 3 position switches It appears that I am only getting high and med, Ignores low rate.
Got timer running off throttle when above idle :)
Next job is "do I have to set both ailerons up independently or use a mix".
Last edit: 02 Oct 2017 16:00 by Phil Ford.
02 Oct 2017 17:28 - 02 Oct 2017 17:29 #13937 by Chris001
The equivalent Spektrum servo travel is -80% to 80%
I use the output tab to set servo end points.
I notice you've set up the switch to be (!SA) are you sure you don't want to pick the one with out the '!' i.e. (SA) I cannot remember what the '!' signifies but I'm pretty sure you don't want it ;)
Why are there two inputs for flaps?
Last edit: 02 Oct 2017 17:29 by Chris001.
02 Oct 2017 18:59 #13946 by Phil Ford
Chris001 wrote: Why are there two inputs for flaps?
Flaps? Two servos.
I'll check the switches again for no ! But the servos worked.
Yes the throws are massive at 100%. i'll set end points at 80% as Spektrum.
So much easier to program on the PC.:)
