Rebuild of E-flite "diamante 25e
  • 4Pedalsfly
23 Aug 2017 23:14 #13585 by 4Pedalsfly
Replied by 4Pedalsfly on topic Rebuild of E-flite "diamante 25e
Repair is at long last finally completed, lots of other things been going on since last posting on the "Diamante".
Still have to resolve a problem with the speed controller then it's air test time.
Thanks to everyone for their comments during this rebuild.
23 Aug 2017 23:35 #13586 by DavidTappin
Replied by DavidTappin on topic Rebuild of E-flite "diamante 25e
Never mind 'Good as New' Colin - that Diamante looks better than new!
What is the problem with the speed controller? I hope it's not the same thing I'm struggling with. I got a replacement from HK for the one which caught fire in my Cub and I don't seem to be able to program it. Phil lent me a programming card but I still can't get it out of slow start mode.
I'm beginning to think it's an age thing. If you're an expert please come and hold my hand!
Tappin the Elder
24 Aug 2017 00:56 #13587 by MikeSeale
Replied by MikeSeale on topic Rebuild of E-flite "diamante 25e
DavidTappin wrote: I still can't get it out of slow start mode.
Remove prop
Switch on transmitter and put throttle stick to full throttle
Connect battery to speed controller and wait for the first set of beeps to finish (a second or two)
Move throttle stick to idle
ESC will beep ... move the throttle stick to full as soon as you hear the beeps
ESC will beep ... move the trottle stick to idle as soon as you hear the beeps
ESC should now play the intro theme music and you're done.
24 Aug 2017 00:58 #13588 by MikeSeale
Looking good there, Colin. Good luck when you come to fly it again.
28 Aug 2017 19:19 #13605 by DavidTappin
Re my speed controller problems, I'm now back in the workshop (after a week in Finland and returning home to find ankle high grass needing urgent attention) and I followed Mikes advice right up to:
Unfortunately I still have slow start up, maybe it's my inability to read tweets (not being a follower of Twitter) it's either that or the ESC is faulty, or I have a hearing problem due to listening to too much live jazz.
Thanks for trying to help Mike, maybe I need to bring it your workshop to test your hearing.
Regards, David
  • 4Pedalsfly
22 Feb 2018 09:47 #15814 by 4Pedalsfly
To complete the "Diamante" rebuild thread I'm pleased to say that I finally got round to flying
her on 21st February 2018 - pic attached.
The post rebuild maiden was "interesting", on all maidens I have someone standing by me to input
any trims to allow me to concentrate on keeping the model straight and level.
On this occasion Tim Sullings was the "trim man" & boy it was needed. The model was nosing down quite badly
and also turning slightly to the left under power.
After trim inputs it still felt wrong so I decided to land her, the landing being a great three pointer.
So it's back into the workshop to check the C.G. , incidences & motor thrust.
My gut feeling is there too much downthrust on the motor but I did not want to prolong the flight to do the usual tests.
So watch this space for the next flight.
22 Feb 2018 11:39 - 22 Feb 2018 11:40 #15815 by JonTappin
Replied by JonTappin on topic Rebuild of E-flite "diamante 25e
Hi Colin
After you put in the required up elevator trim, if it was the thrust line that was the problem, it would have pitched up when you throttled back to land. Did it do this? If not it is more likely to be an incidence problem. Assuming it is a symetrical wing section, you should have between 0.5 and 1 degree positive on the wing.
Glad you managed to get it down safely!
Hope this helps.
Last edit: 22 Feb 2018 11:40 by JonTappin.
  • 4Pedalsfly
22 Feb 2018 22:23 #15816 by 4Pedalsfly
JonTappin wrote: Hi Colin
Hope this helps.
Jon - Many thanks for your comments, I have shed time tomorrow & will check the airframe over with the incidence meter.
We never got enough elevator up trim to achieve hands off level flight, rather than continue fighting it I decided to go
for a landing, which was a good three pointer.
  • 4Pedalsfly
25 Feb 2018 19:01 #15825 by 4Pedalsfly
Jon - I set the model up with the fuselage datum line at zero degrees.
Wing incidence 0 degrees
Tail incidence 0 degrees.
Motor Downthrust 2 degrees.
C of G spec is 127 to 140 mm - actual - 134 mm.
I'm proposing to lower the wing at trailing edge to give 1/2 degree positive incidence.
Is this the best way to go ?
Thanks
25 Feb 2018 20:23 #15826 by JonTappin
Hi Colin
Yes you need incidence on the wing, with 0-0 you will need up elevator trim to fly level. I would add a minimum of 0.5 positive on the wing. Is it an easy job to add it?
