Burnt Out Motor
10 years 2 weeks ago - 10 years 2 weeks ago #6277 by Phil Ford
Replied by Phil Ford on topic Burnt Out Motor
Chris, I am assuming that you pre-programmed the ESC before actually using it to fly. It may work without making settings changes on the bench but in flight that is a different matter. There are at least 6 settings to check. General order is: Brake on/off, cell type, number of cells/auto check, power down voltages, start up, etc. etc.
This has been mentioned in this thread before but - overheating motor? timing not suitable for motor or to high (in other words like gas engines, too far advanced. High timing can give increase in power but at a cost, eg heat. Usually default settings on most ESC is "middle" but that could be 12 deg or 15 deg depending on maker. Do you have a programming card which is the easiest to use but programming can be done by the TX throttle stick. I am sure somewhere I read some time ago that AXI motors don't like high timing settings. I do know that the AXI 4120/18 like low timing. Check the ESC settings before connecting to motor with out prop on!
I have cards to program Turnigy, Hobbywing, YEP, Black Mantis ESCs. Probably one of them is compatible with what you have.
My preference is use an ESC with 25% minimum capacity over and above what I am likely to ever demand. ;)
Last edit: 10 years 2 weeks ago by Phil Ford.
10 years 2 weeks ago #6279 by Chris73
Replied by Chris73 on topic Burnt Out Motor
I think the safest option is to wait for the new motor to arrive and then ask one you kind people to check it for me before I fly again
10 years 2 weeks ago - 10 years 2 weeks ago #6280 by Phil Ford
Chris73 wrote: I think the safest option is to wait for the new motor to arrive and then ask one you kind people to check it for me before I fly again
Good bet! ;)
I was not condemning AXI motors, they are supposed to be good, but for the size motor you are using - £90+. Would have to be a serious model for me to drop that in :( Their outrunners are made under contract in China but apparently the Inrunners are still made in Czech.
Time to create page: 1.996 seconds
