3D profile foamie recommendations
  • AlanF
01 Nov 2015 18:18 - 01 Nov 2015 18:24 #6809 by AlanF
3D profile foamie recommendations was created by AlanF
I fancy a chuckabout 3D profile foamie around 30-40 inch span, robust and easily repairable, not too expensive, either kit or preferably ARTF. Does anyone have any recommendations? or at least ones to avoid. I'm fairly clueless with leccy stuff. Also I can only charge Max 6S at 5A
And suitable for Cashmoor
Last edit: 01 Nov 2015 18:24 by AlanF.
01 Nov 2015 18:32 #6810 by DaveBright
Replied by DaveBright on topic 3D profile foamie recommendations
Telink...... You've seen my profile yak55 foamy thing. Robot birds stock telink.
Chris H has recently bought one too.
Good fun, bounces (unless you've had a few and cease to able to fly at all!) but even then, the epp goes back together quickly. Will do 3D, but won't flat spin.
I'm sure hobbyking will also stock similar products so maybe worth a look there too. Depends on your budget.
01 Nov 2015 18:53 #6811 by MikeSeale
Replied by MikeSeale on topic 3D profile foamie recommendations
Telink get my vote too. Being a little bigger they can handle the Cashmoor wind a little better. However, they take up a lot of room in the car and at home, so make sure you go into this venture with your eyes open.
  • AlanF
01 Nov 2015 18:55 #6812 by AlanF
Replied by AlanF on topic 3D profile foamie recommendations
That's the sort of thing Dave, thanks. Did you use the RobotBirds power package or spec the motor and servos yourself? If I just buy the air-frame I'm going be asking lots of questions!
01 Nov 2015 19:01 #6813 by Chris73
Replied by Chris73 on topic 3D profile foamie recommendations
Just as easy to buy the whole set up from them, as Mike has already said they take up more room than you think. Lots of fun though :woohoo:
  • AlanF
01 Nov 2015 19:04 #6814 by AlanF
MikeSeale wrote: Telink get my vote too. Being a little bigger they can handle the Cashmoor wind a little better. However, they take up a lot of room in the car and at home, so make sure you go into this venture with your eyes open.
I did notice that they do removable wing versions. That may be worth considering.
  • AlanF
01 Nov 2015 19:09 #6815 by AlanF
Chris73 wrote: Just as easy to buy the whole set up from them, as Mike has already said they take up more room than you think. Lots of fun though :woohoo:
Thanks for that Chris, I'd prefer a complete package so I don't have to think too much. Apart from motor, ESC servos, RX, and batteries what else did you have to buy?
01 Nov 2015 19:11 #6816 by Chris73
couple of props and a tube of uhu por and your done :)
01 Nov 2015 19:12 #6817 by JonTappin
Replied by JonTappin on topic 3D profile foamie recommendations
Lots of spare props :)
The Extravaganza flies very well Alan and I have proved it is very strong!
01 Nov 2015 19:12 #6818 by Chris73
If you get the removable wing version, don't do what Dave B did :silly:
Time to create page: 0.438 seconds
