28 Nov 2016 19:45 - 28 Nov 2016 19:46 #10955 by Phil Ford
I am trying to picture in my mind how far you have got. :unsure: It is a not easy to help when not able to see the animal in the flesh.
Okay, so the throttle barrel is now shutting closed and when at full throttle the link stop just hits the engine bolt now I imagine? Yes?
Not drawing fuel? It must be if your getting hydralock (excess fuel in cylinder). Don't force the engine over compression, you may bend the conrod. Either pull the glow plug out and flick it over or wind carefully backwards so that the exhaust valve opens and dumps the fuel out through the exhaust.
Are you able to creep up to the field Tuesday? I should be there most of the day.
We know you have good compression so valve clearances are acceptable.
Last edit: 28 Nov 2016 19:46 by Phil Ford.
  • G_O_L_D
28 Nov 2016 20:54 #10956 by G_O_L_D
Replied by G_O_L_D on topic Help required OS 70 - 4 Stoke (Acro WOT)
yes valve open right way now the throttle servo is reversed , getting worried about this locking up though :dry: :(
28 Nov 2016 21:44 #10958 by Phil Ford
If you can get up to Cashmoor tomorrow I can take the Acro home and see what the problem is Lee. Then I give you a rundown on the situation so you will know if there is ever another model with the similar issue.
The following user(s) said Thank You: G_O_L_D
29 Nov 2016 15:50 #10961 by Brian
Lee, if you reversed the servo, you must re-bind the receiver's fail safe, otherwise you'll have the engine going to full throttle if you have a radio problem.
  • G_O_L_D
01 Dec 2016 17:45 #10980 by G_O_L_D
Brian, Fail safe redone done that straight away, but thanks ;)
Phil that would be extremely useful thanks :woohoo:
01 Dec 2016 18:38 - 01 Dec 2016 18:40 #10981 by Phil Ford
I'll probably be up on Saturday Lee, so I can take the "thing" home or at least give me the engine. I can set up the latter on my test bed and sort it.
Trying to do indoor jobs as much as possible due to the cold weather....... ;)
Last edit: 01 Dec 2016 18:40 by Phil Ford.
  • G_O_L_D
02 Dec 2016 07:39 #10984 by G_O_L_D
if your about at home this afternoon i can pop the "thing" in lol
agree its bloody to cold out !
02 Dec 2016 09:13 #10985 by Phil Ford
You fancy a trip to Christchurch? :unsure: I'll be here. Have sent a message.
02 Dec 2016 17:34 - 02 Dec 2016 17:35 #10990 by Phil Ford
For those that are interested ;) here is the story so far. Engine removed from Acrowot and put on test bed. Virtually nothing, a few seconds of combustion and nought else. :( Right, exchange glow plug for new OS F type. Remove carb and mainjet and blow out with compressed air.
Hello! what's this? Carb bracket on crankcase casing broken. :( Manifold gasket a bit compressed and wet therefore suspect possible air leak. :( Check valves at same time. Nope! Some tw*t has broken one of the screw heads off. This is a LOST cause. As it happens I have a similar engine which Lee saw running earlier. Sold! :)
I have fitted it to the Acrowot but the throttle linkage will need moving back to where it previously was located. While the engine is off, might as well cover all bases and pull out tank. Oh dear! Tank bung perished, clunk touches back of tank, lines a bit soggy too. The tank also had two exhaust lines hence the drain line did not drain... Engine mounting bolts - two too long and hitting tank.
Bung and lines replaced, (coloured one for carb line) all plumbing replaced and new ally pipe for carb line (the other one was corroded. All I have to do now is make up a new linkage using the snake I moved earlier. Lee, I have re-secured the battery for easier access whilst I was at it. ;) Mixture screw is now accessible from top - much safer.
Last edit: 02 Dec 2016 17:35 by Phil Ford.
  • G_O_L_D
02 Dec 2016 18:30 #10992 by G_O_L_D
Yep, spent some time with phil this afternoon, wasn't impressed with the engine at all after we came to the conclusion that is was knackered, (yeh mate i started it couple weeks ago (Cough cough BullS!h7) springs to mind), yes phil had another engine thankfully that would fit, Now left at his looking very sorry for itself with a part rebuild by looks of it.
Thank god for people who actually know what they doing ! and a massive thanks to phil for what he done! with some help of others too
Thanks to all, hopefully this should solve it finally, least the Airframe in good nick !
Ebay seller will be getting an earful !
