AeroTech Pitts Python 50cc
05 Sep 2018 19:06 #17593 by JonTappin
Replied by JonTappin on topic AeroTech Pitts Python 50cc
Phil Ford wrote:
I assume you cut it to shape and use Gorilla where it touches the GRP cowl?
Yes, but I don't know how much you are cutting away, I would think you would need a reasonable amount of contact area, otherwise the vibration will loosen it fairly quickly
10 Sep 2018 19:05 - 11 Sep 2018 08:13 #17631 by Phil Ford
Slope soaring day tomorrow so spent today assembling the Pitts fully (as would have to be done at the field). A few niggles with the interplane strut bolts though. After the run up I then spent the afternoon cutting a slot in the lower cowl directly in front of the cylinder head. Unfortunately the air scoop can not be fitted. :( Exhaust had a slight blow (oil stains appearing) so cleaned up the mating surfaces and used high temp silicon copper to seal it. Throttle curve re-adjusted for a linear feel. Set up the elevators as they were not operating together - a few turns on the control rods sorted that out. Just the ailerons to check now.. Once I am happy with everything I will make up some wing wires for scale effect in the near future.
If you got 5 mins spare watch the video...;)
Last edit: 11 Sep 2018 08:13 by Phil Ford.
Time to create page: 0.261 seconds
