Prop Drilling
7 years 1 week ago #17426 by JRI
Replied by JRI on topic Prop Drilling
PM'd you Chris - come round any time Saturday eve or Sunday.
7 years 1 week ago #17429 by DavidTappin
Replied by DavidTappin on topic Prop Drilling
1/4" is only 10 thousands of an inch more than 6.1 mm which is the hole size you would be likely to end up with using a badly sharpened 6.1 mm drill!
7 years 1 week ago #17430 by JRI
DavidTappin wrote: 1/4" is only 10 thousands of an inch more than 6.1 mm which is the hole size you would be likely to end up with using a badly sharpened 6.1 mm drill!
Ther are 40 thou in a mm so the diference between 6.0mm (nominal bolt size) and 6.35mm (1/4") is only 14 thou'!
I agree with Dave, go for 1/4" or even 6.5mm otherwise swelling wood or tiny discrepencies in the drill guide will cause sticking bolts and consequent stripped threads in the hub. I think I have drilled out my guides to 6.5mm anyway so no point in trying for better unless you use a huge mill/drill and a dividing-head.
Time to create page: 1.102 seconds
