New to glow engine
6 years 1 month ago #20682 by
New to glow engine was created by
Hi guys so I ended up with this awesome looking piper cub... as I am new to the glow engine planes I am unsure of what fuel I should be using ? .. the motor looks very clean has compression it's a irvine 40 check out the photos .. I think it has a good chance of running ..
Thanks Dan
6 years 1 month ago #20684 by Chris73
Replied by Chris73 on topic New to glow engine
I am sure you will get lots of different opinions on the fuel to use, but personally I don't think you can go wrong with Contest 10
6 years 1 month ago #20688 by JRI
Replied by JRI on topic New to glow engine
Contest 10 is great stuff (also known as "Formula Irvine").
I have had a few Irvines and the starting point for the needle settings is invariably:
3.75 turns out for the idle jet screw.
1.75 turns out for the main jet.
Good luck.
6 years 1 month ago - 6 years 1 month ago #20695 by Phil Ford
Replied by Phil Ford on topic New to glow engine
Chris73 wrote: I am sure you will get lots of different opinions on the fuel to use, but personally I don't think you can go wrong with Contest 10
Yup! Agree. Good all rounder I use it all the time.
Dan, Remote glow? If it has an on-board auto glow on the two stroke it is because the engine is inverted and unburned fuel can kill the glow heat.
Last edit: 6 years 1 month ago by Phil Ford.
6 years 1 month ago #20700 by
Replied by on topic New to glow engine
Doesn't have a on board glow just wire up to a glow plug on top of the plane .. I guess for easier accsess
6 years 1 month ago - 6 years 1 month ago #20701 by Phil Ford
Inverted glow engine means on "hand n knees" to attach glow igniter and near a spinning prop. Also convenient and safer when disconnecting.;) Glad to see someone going with IC. :)
Time to create page: 0.498 seconds
