New to glow engine
  • Dan287
01 Sep 2019 19:03 #20682 by Dan287
New to glow engine was created by Dan287
Hi guys so I ended up with this awesome looking piper cub... as I am new to the glow engine planes I am unsure of what fuel I should be using ? .. the motor looks very clean has compression it's a irvine 40 check out the photos .. I think it has a good chance of running ..
Thanks Dan
01 Sep 2019 20:23 #20684 by Chris73
Replied by Chris73 on topic New to glow engine
I am sure you will get lots of different opinions on the fuel to use, but personally I don't think you can go wrong with Contest 10
02 Sep 2019 08:08 #20688 by JRI
Replied by JRI on topic New to glow engine
Contest 10 is great stuff (also known as "Formula Irvine").
I have had a few Irvines and the starting point for the needle settings is invariably:
3.75 turns out for the idle jet screw.
1.75 turns out for the main jet.
Good luck.
The following user(s) said Thank You: Dan287
02 Sep 2019 17:59 - 02 Sep 2019 18:04 #20695 by Phil Ford
Replied by Phil Ford on topic New to glow engine
Chris73 wrote: I am sure you will get lots of different opinions on the fuel to use, but personally I don't think you can go wrong with Contest 10
Yup! Agree. Good all rounder I use it all the time.
Dan, Remote glow? If it has an on-board auto glow on the two stroke it is because the engine is inverted and unburned fuel can kill the glow heat.
Last edit: 02 Sep 2019 18:04 by Phil Ford.
  • Dan287
03 Sep 2019 12:55 #20700 by Dan287
Replied by Dan287 on topic New to glow engine
Doesn't have a on board glow just wire up to a glow plug on top of the plane .. I guess for easier accsess
03 Sep 2019 14:39 - 03 Sep 2019 14:39 #20701 by Phil Ford
Inverted glow engine means on "hand n knees" to attach glow igniter and near a spinning prop. Also convenient and safer when disconnecting.;) Glad to see someone going with IC. :)
Last edit: 03 Sep 2019 14:39 by Phil Ford.
  • Dan287
03 Sep 2019 22:23 - 03 Sep 2019 22:24 #20704 by Dan287
So will I need to invest in a on board glow heater for it run good or will be ok how it is ?? And yes looking forward to flying i/c planes .. just got to save some cash and invest in some gear to get it running
Last edit: 03 Sep 2019 22:24 by Dan287.
04 Sep 2019 08:33 #20706 by Phil Ford
No, you don't need an onboard auto glow unless you cannot achieve a reliable idle. Fly it first! No need to spend money willy nilly. ;)
04 Sep 2019 08:36 #20707 by JonTappin
Replied by JonTappin on topic New to glow engine
Hi Dan
I wouldn't bother to go with an onboard glow yet if it was me. I've run lots of inverted glow engines in the past and have never needed to. I would try it without and then if you do have issues that can't be solved with proper tuning, then consider it later.
The main issue with inverted 2 strokes is with starting, as if it is too wet it can put the glow plug out and even hydraulic lock if it's really wet. Starting with the model upside down or on its side with the exhaust down makes this easier. On board glow obviously does not help with this!
Time to create page: 0.322 seconds
