Baffle or no baffle, that is the question
  • Hobby1964
02 Jan 2021 17:58 #23953 by Hobby1964
Hi guys, so I’m fitting the FG-60 r3 in a Corsair. Should I baffle or will it be ok without. I see a lot of planes fitted with this engine without but thought I’d better check as radials are new to me.
02 Jan 2021 19:08 #23955 by kevinross
Replied by kevinross on topic Baffle or no baffle, that is the question
i think it depends on the outlet area but if in doubt MMM sell these - I think Dave Bright has fitted one in his FG60
www.morrisminimotors.com/saito-fg-60-r3-...e-baffle-mmmb-3.html
The following user(s) said Thank You: Hobby1964
02 Jan 2021 19:47 #23959 by 4Pedalsfly
Replied by 4Pedalsfly on topic Baffle or no baffle, that is the question
I'm not into I.C these days but for interest I keyed in Kevin's link,
baffle is made from 3mm light ply & priced at £24.95.
Simple enough to cut out with the right tools or one can support
this small business.
02 Jan 2021 20:57 #23961 by DaveBright
Replied by DaveBright on topic Baffle or no baffle, that is the question
For ease I bought the baffle linked above. Think it’s a good idea to give these things as much direct cool air as they can get.
I’ve also fitted cooling louvres (behind baffle) to pull the warm air out too. Make sure you’ve got a good size outlet for the hot air.
I’m hoping to run mine soon so will see what the cylinder head temps are like.
02 Jan 2021 21:02 #23962 by DaveBright
Simon Dean has a Corsair with FG84.. can’t recall if he’s baffled or not....
  • Hobby1964
02 Jan 2021 21:52 #23963 by Hobby1964
Replied by Hobby1964 on topic Baffle or no baffle, that is the question
Thanks Dave, it seems as though getting the hot air out is as much of an issue as getting the cool air in. Interesting to see how others overcome this. I suppose I presumed that the Corsair has such a large, unobstructed opening that the baffle wouldn’t be necessary but I think it’s perhaps it’s actually the amount of open space that is the issue as the majority of the air can more or less bypass the engine giving no cooling at all whereas with the baffle, the air that gets in there is forced across the engine fins giving better cooling. I think I will go for the baffle. I like the way your’s looks as you can still see that lovely looking engine. Much better than the imitation engine which comes with my kit. Ok, I know it’s not 100% scale but neither are a few other features so no big deal.
03 Jan 2021 10:16 #23964 by JonTappin
Replied by JonTappin on topic Baffle or no baffle, that is the question
I think it's definately worth the extra effort to baffle Jeff, better cooling will never be a negative thing, will give much better protection in case of a lean run.
Air always takes the easiest route, so even with the big clear opening that the Corsair has, most of the air will go round the heads rather than through the fins, baffling forces it through them like you say.
Easy enough to make a paper template, then cut it from light ply, or for non modellers like Dave, you can just buy one :)
03 Jan 2021 10:52 #23965 by DaveBright
Jon Tappin wrote: I think it's definately worth the extra effort to baffle Jeff, better cooling will never be a negative thing, will give much better protection in case of a lean run.
I dislike you :-)
  • Hobby1964
03 Jan 2021 12:43 #23966 by Hobby1964
Thanks Jon, I’ve decided to baffle. Like I posted before, you would think you would get plenty enough air in their without but as I’m aware from my pump background, what you think will happen certainly doesn’t always and there are a lot of things to consider which are not always obvious to the novice.
  • Hobby1964
03 Jan 2021 12:46 #23967 by Hobby1964
Poor Dave, bit harsh
