Baffle or no baffle, that is the question
03 Jan 2021 16:13 - 03 Jan 2021 16:14 #23969 by Phil Ford
Replied by Phil Ford on topic Baffle or no baffle, that is the question
Jeff Hobby wrote: Poor Dave, bit harsh
That's nothing Jeff compared with what he usually gets...:lol:
Back to the issue, I believe the rule of thumb was that the air flow exit size at least twice the air flow in but not always so easy in practice. Scale models the worst I think because you just cannot hack holes where needed or it ruin it's looks.
Last edit: 03 Jan 2021 16:14 by Phil Ford.
03 Jan 2021 17:23 #23971 by JonTappin
Replied by JonTappin on topic Baffle or no baffle, that is the question
I did it for you Jeff, payback for the finger incident :)
04 Jan 2021 09:46 - 04 Jan 2021 09:46 #23975 by Phil Ford
:lol: Another roasting for poor Dave. I am "baffled" as to why Dave gets reminded of "classic fails" :unsure:
Last edit: 04 Jan 2021 09:46 by Phil Ford.
04 Jan 2021 09:48 #23976 by Phil Ford
Speaking of baffles Jon, would foam board cope glued into a grp baffle. I think you said it was fine.:unsure:
04 Jan 2021 12:36 #23978 by JonTappin
I have used card faced foam board for baffling around flat twins and it's fine, I'm not certain it would be as good for a radial baffle as the air would be hitting it on its flat face, so may not be strong enough to cope with the pressure
04 Jan 2021 12:37 #23979 by kevinross
Replied by kevinross on topic Baffle or no baffle, that is the question
I remember reading an article by Brian Winch about the Saito engines in which he emphasised the need to cool the crankcase. Note that the FG 84 & 90 have additional cooling fins attached to the crankcase in between the cylinders for good reason. So a simple flat baffle might not be ideal. This link has some useful info on Saito baffle construction. note that provision is made to cool the crankcase fins.
www.modelairplanenews.com/make-cooling-b...-engine/#outer-popup
  • Hobby1964
04 Jan 2021 18:36 #23981 by Hobby1964
Replied by Hobby1964 on topic Baffle or no baffle, that is the question
Thanks Kevin, I saw that article and like you say the larger engines have those cooling fins on the crankcase. Not sure if similar is required on the 60. Pictures are where I’m at up to now.
  • Hobby1964
04 Jan 2021 18:38 #23982 by Hobby1964
Comments/criticism gladly received please
04 Jan 2021 20:24 - 04 Jan 2021 20:26 #23983 by JonTappin
Looks good Jeff but you need to open up in front of the crankcase heat sinks as well.
Saved yourself 25 quid as we'll :)
Last edit: 04 Jan 2021 20:26 by JonTappin.
  • Hobby1964
04 Jan 2021 20:35 #23984 by Hobby1964
Thanks Jon. But the 60 doesn’t have those heat sinks on it
Time to create page: 0.339 seconds
