So That Was What It Was!
01 Jul 2021 11:19 #24847 by Jonjacobs
Replied by Jonjacobs on topic So That Was What It Was!
My setup is exactly the same and works perfectly.Can’t understand what the problem might be but I’d give it another go because the GP silencer is REALLY NOISY.
01 Jul 2021 11:26 - 01 Jul 2021 11:27 #24848 by Phil Ford
Replied by Phil Ford on topic So That Was What It Was!
Jon, here is part of a topic on Flying Giants is verifies my thoughts - www.flyinggiants.com/forums/showthread.php?t=287709&page=5
and www.flyinggiants.com/forums/showpost.php?p=3116127&postcount=73
At present there appears to be no good answer to the muffler issues with GP engines, at least in the USA and Canada.
Last edit: 01 Jul 2021 11:27 by Phil Ford.
09 Jul 2021 09:22 - 09 Jul 2021 09:23 #24878 by Phil Ford
Update: Well here is my final view and answer :unsure: on this subject. On Thursday 8th I did a quick noise test with the help of Simon with the GP original "muffler" fitted. Taken at ground level at a distance of 7 metres at WOT = RPM 7650. Prop Falcon 20x8 Front 94db, Sides 90 db, From Behind 86 db. The "bark" from the exhaust at any thing above half throttle is not nice. So, I have decided that at the moment the Extra is NOT flyable. If the OS exhaust is fitted I lose 1000rpm and max out at 6600. An option is to try a 22x10 prop but that might be just too much load, moving in to the 50cc domain here I think. I don't know which way to go for now. :(
Last edit: 09 Jul 2021 09:23 by Phil Ford.
  • Chris Hughes
09 Jul 2021 12:02 #24881 by Chris Hughes
Replied by Chris Hughes on topic So That Was What It Was!
Tuned pipe :woohoo:
  • Chris Hughes
09 Jul 2021 12:07 #24882 by Chris Hughes
You said you got the OS exhaust from BMFA, was it new or second hand??
If it was second hand there is a possibility that it is clogged up
09 Jul 2021 15:58 #24883 by 4Pedalsfly
Replied by 4Pedalsfly on topic So That Was What It Was!
Phil - General opinion from the pits area confirms your test results.
PLANE TOO NOISY.
09 Jul 2021 18:13 - 09 Jul 2021 18:13 #24884 by Phil Ford
Chris Hughes wrote: You said you got the OS exhaust from BMFA, was it new or second hand??
Brand new in box Chris.
Last edit: 09 Jul 2021 18:13 by Phil Ford.
09 Jul 2021 20:49 #24887 by JRI
Replied by JRI on topic So That Was What It Was!
Did you take it out of the box before fitting it Phil ? ;)
10 Jul 2021 10:06 #24888 by Phil Ford
Yes John, I do remember taking it out of the box. Although if it is anything like washing machines I am wondering if there is some transport foam inside to protect the innards from damage.
Time to create page: 0.334 seconds
