OSFS 1.20 Surpass Mklll
  • Brian Jackson
06 Oct 2021 17:22 #25232 by Brian Jackson
OSFS 1.20 Surpass Mklll was created by Brian Jackson
The OS 1.20 has just been removed from Simon's WOT 4 XL. A while ago, Simon had problems with the engine, it would start but wouldn't run cleanly. At the time it was thought that either the pump or the carburettor diaphragm was the cause. Both items apparently difficult to find. All I have done so far is set up the throttle servo and linkage, this had the engine starting easily and running well. However, at tick-over, the sound of the exhaust was drowned out by the sound of noisy bearings. Today being warm and sunny, it seemed like a good time for an engine strip down. Everything went well until I tried to remove the screws holding the cylinder head. After heating the head and tapping the screws with a small drift, most of the screws came out easily, only two are left, a 3mm buried in the area of the rockers and a 4mm just behind the glowplug. I can't move the 3mm as the only key I have is a ball ended one, and its a slack fit so can't be used. The 4mm screw is rounded over and the key will never grip it. I've ordered some new keys from Screwfix, all without ball ends so can be used in tight areas. The method I'm going to use to get the 4mm screw out was shown to me when I was an apprentice, its a bit brutal to the Allen key, but it seems to work quite well. The method is to use a grinding wheel, this is the brutal bit, the Allen key is rammed hard into the wheel (which should be spinning at full speed) Just a short sharp jab is all that's needed. The result is a distinct burr on the end of the key. Making sure that the damaged socket is completely free from debris, align the key with the socket and push it in firmly. If it doesn't work the first time, it usually does on the second attempt..
No wonder the bearings are noisy, the main bearing is a mass of rust, I assume the front bearing's the same as its been leaking nasty brown oil behind the prop driver.
  • Brian Jackson
06 Oct 2021 18:46 #25233 by Brian Jackson
Replied by Brian Jackson on topic OSFS 1.20 Surpass Mklll
The "4mm" screw was in fact a 3mm screw and matched the rest of the screws in the cylinder head. Don't know why I thought the screw was bigger. Perhaps today wasn't a good choice for engine stripping, I was lulled by the sunshine and needed something to concentrate on. Yesterday morning we had our third Covid jabs, I was OK until lunchtime, then things went a bit wobbly for the rest of the day. Only began to shake off the after effects late this afternoon.
I've just been to Screwfix for some cheap Allen keys, the burr on the key did its job first time, and now all the screws are out. As a precaution I'll replace all of them and re-tap all the holes before assembling the head.
06 Oct 2021 19:14 - 06 Oct 2021 19:15 #25234 by JRI
Replied by JRI on topic OSFS 1.20 Surpass Mklll
They are NOT 3mm screws Brian - they are 3.5mm and as rare as hens teeth and brand new too! The threads in the cylinder were perfect when I replaced the head, and they were lightly oiled (no loctite or similar used)!!
Last edit: 06 Oct 2021 19:15 by JRI.
06 Oct 2021 19:19 - 06 Oct 2021 19:23 #25235 by kevinross
Replied by kevinross on topic OSFS 1.20 Surpass Mklll
sorry if i'm telling you how to "boil an egg" Brian but i would be be very reluctant to re tap the threads as you could very easily remove metal. I would prefer to just run a good bolt in & out. Also double check the threads which may not be M3 x 0.5 pitch
These hex drive bits would provide better performance on stubborn screws
www.ebay.co.uk/itm/402352414911
Last edit: 06 Oct 2021 19:23 by kevinross.
06 Oct 2021 19:46 - 06 Oct 2021 20:02 #25236 by JRI
THEY ARE M3.5 !!!!!!!!!!!!
THAT IS WHY THE M3 HEX KEY DOES NOT FIT !!!
DO NOT RE-TAP THE THREADS M3 or M4 OR YOU WILL RUIN THEM !!!!!
www.modelfixings.co.uk/high_tensile_steel_caps.htm do the screws if the heads are now trashed (MF-SC31 M3.5 x 20 Cap Screws (pack of 5) )
Last edit: 06 Oct 2021 20:02 by JRI.
  • Brian Jackson
06 Oct 2021 20:17 #25237 by Brian Jackson
Thanks for your input Kevin and John, the screws are of course M3.5 X 20mm, I've found the relevant OS manual and printed it, Model Fixings have the screws, unfortunately they sell them in 5s, nuisance when you need 6. I don't know much of the history of this engine, or who did what to it. All I'm concerned with is getting it right and getting it running properly. It has been encouraging to find that setting up the throttle throw had the engine starting very easily, running and throttling quite well. There is an issue with the bearings, the main is very rusty and I assume the front bearing is the same due to the dark oil leaking out. The tappets are a bit noisy and are worn, perhaps caused by lack of oil. Repolishing the contacting surfaces should cure that.
I noted your second reminder John, I could read it without my glasses!
The reason I'm considering retapping at least one hole is that the screw which I mistakenly described as "M4", was rounded over and difficult to get out. Funny thing though, when it was the only screw holding the head on, the head was free to move although the screw was seized solid, the screw hadn't gone home fully as there was at least 2mm of head movement, hence I feel that something is preventing the screw from being fully driven home.
  • Brian Jackson
06 Oct 2021 20:42 #25238 by Brian Jackson
The tapping would be done with a 3.5 X 0.6 plug tap held in a pin vice Kevin, minimises the risk of damaging the existing thread.
07 Oct 2021 00:00 #25240 by 4Pedalsfly
Replied by 4Pedalsfly on topic OSFS 1.20 Surpass Mklll
Brian - In my I.C days I use to get bearings from ARB Bearings on the Ferndown Industrial Estate - Tel 01202 862730.
Very helpful people & good prices.
Laser engines used to use B.A Socket Head cylinder head screws - even rarer than hens teeth - thankfully they eventually
went Metric.
  • Brian Jackson
08 Oct 2021 15:04 #25253 by Brian Jackson
Apart from the cylinder head complete with newly installed valves, the OS is now completely dismantled. The lack of oil around the cam shaft and cam followers seems to be caused by a blocked oil hole. Not surprised when I saw the amount of gunk from the rusty bearings. Satisfying task ahead, prepping the parts for re-assembly, nice job for a rainy day.
  • Brian Jackson
10 Oct 2021 14:49 - 10 Oct 2021 14:53 #25260 by Brian Jackson
The engine parts have cleaned up nicely, the vent nipple from the cam gear has been cleaned out, the last task was to remove the camshaft bearings. Access to these bearings is from one side only, bit tricky to remove, they didn't loosen when the crankcase was heated and lacking a bearing puller, I resorted to the method I learned long ago when working on aileron bearings for the DH Vampire. I didn't have any suitable grease, so I used candle wax.
The wax was shaved into small bits that could be poked into the bearing bore, the wax was tamped down using the shank of a 5mm drill bit, banged in with a plastic faced mallet. Sounds drastic but isn't damaging at all. After several additions of wax shavings and a few whacks with the mallet, both bearings were removed from their housings.
The debris on the crankcase is bits of plastic from the mallet, tends to happen when beating a drill bit on its sharp end.
Last edit: 10 Oct 2021 14:53 by Brian Jackson. Reason: Additional information.
Time to create page: 0.356 seconds
