That engine sounds a bit sick! ...
  • AlanF
15 Aug 2013 09:57 #226 by AlanF
Replied by AlanF on topic That engine sounds a bit sick! ...
PhilF51 wrote: I am surprised the engine didn't self destruct with that damage. One of my JEN 90 two strokes had a bearing failure and I only found out when testing it in a model at home, the vibration was more like a four stroke and squeal noise when throttling up!
Funnily enough the noise didn't worry me at the time (it will do in future!) it was the black exhaust goo that triggered my concern.
A lot of work and running about for what is a write-off for your 46, Alan.
I've never stripped an engine before so it's been a useful learning experience. If I can get hold of a piston and liner in reasonable condition for cheap I'll put it back together. Other than that it's a write off.
I suggest you purchase "as new" OS 46 from me and get into the air asap.. ;)
I have two OS 46's available. PM me if interested.
Thanks for the heads up Phil but I've already taken delivery of a new SC 46. I'm a glutton for punishment :ohmy:
15 Aug 2013 23:28 #232 by 4Pedalsfly
Replied by 4Pedalsfly on topic That engine sounds a bit sick! ...
Alan - When I was running Laser 4 Strokes I found the following very good value :
ARB Bearings - Unit B14 - 9 Nimrod Way, Ferndown Ind Est - BH21 7SH - tel 01202 862730.
For cash the prices were better !!
Hope this helps.
Colin.A
  • AlanF
16 Aug 2013 10:05 - 16 Aug 2013 10:06 #234 by AlanF
Thanks for that Colin. I just had a quick look at their website and they seem to have what I need if I ever go ahead with the rebuild. They're not far from me so it's worth knowing they are there.
Last edit: 16 Aug 2013 10:06 by AlanF.
16 Aug 2013 11:16 - 16 Aug 2013 11:17 #235 by Phil Ford
Replied by Phil Ford on topic That engine sounds a bit sick! ...
I have one of them too with a choice of mufflers... ;)
Last edit: 16 Aug 2013 11:17 by Phil Ford.
Time to create page: 0.334 seconds
