ASP 120 4 str Not playing ball!
01 Feb 2015 14:48 - 01 Feb 2015 14:48 #3688 by Phil Ford
ASP 120 4 str Not playing ball! was created by Phil Ford
Well, rather than going to the slope I decided to stay at home in the cold drive and get the ME109 engine running. Wished I had gone sloping! :(
The new engine starts okay but will not pick up from idle or maybe a little fast idle. Runs for a half a minute and stops. I have fiddled and flicked till I was tempted to go into the garage and find the original 90 2 str and stick it back in. :angry: But I don't want to succumb to defeat yet. ;) The reason for a four stroke was for scale effect and the fact that when the 2 str was in I had to start it with the model inverted
I tried walking away for a break and a cup of tea but this didn't help either.
Any thoughts and things I may have missed?
Last edit: 01 Feb 2015 14:48 by Phil Ford.
  • Phil-C
01 Feb 2015 15:52 #3689 by Phil-C
Replied by Phil-C on topic ASP 120 4 str Not playing ball!
My ASP 70 FS took ages and a lot of input from others before finally I had an engine that worked. I spent weeks starting the model at the field, with it cutting on me when I throttled up.
The idle screw was the culprit. It went in about 2.5 turns from as delivered state and is very very sensitive.
One bit of advice I was given was how to set the idle initially. Take off the fuel feed to the carb and replace with a short length of clean pipe. Then, with the needle valve closed, blow into the fresh pipe and adjust the idle crew until it is just letting air through. It won't be right, but it will run. You can then tune it to get reliable running.
Later on, after many flights without engine problems, I couldn't start it at all. I replaced all the pipes and found that the one connected to the silencer was blocked with exhaust muck at he silencer nipple. A new pipe cured that.
Only had these problems with the ASP.
01 Feb 2015 17:23 - 01 Feb 2015 17:25 #3692 by Phil Ford
Replied by Phil Ford on topic ASP 120 4 str Not playing ball!
I have done most of what you have suggested. I took the engine back out of the me109 and mounted it on my test bed. Not ideal as it really suits two strokes and their carb faces a upwards. Four stroke will be pointing down so choking it is not that easy at all. Got it running at a fast idle for about a minute or so but it died before I could tweak it. I have to keep turning the engine upside down to get fuel into the manifold. Getting covered in it too! Light failing so gave up for now. :(
You just know you have crap engine from day one! :angry:
However, where it has been running the compression has come up well so the ring has started to bed in.
Might have stick it back in the me109 to play with it unless someone has a jig for four strokes.
In future I am sticking with electric, less fuss and clean
Last edit: 01 Feb 2015 17:25 by Phil Ford.
01 Feb 2015 19:11 - 01 Feb 2015 19:12 #3696 by Phil Ford
Have found an old thread regarding these ASPs and the factory jet settings are: low 4 1/2 turns in from fully out. High is: 2 1/2 turns from closed. That's a starting point at least (excuse the pun) I'll have another go maybe tomorrow. :unsure:
Last edit: 01 Feb 2015 19:12 by Phil Ford.
02 Feb 2015 11:15 - 02 Feb 2015 11:17 #3709 by Phil Ford
Here it is so far. Blowing down exhaust pressure line I can get fuel pouring out of carb line. Put a few drops of fuel down carb mouth and it'll fire and run for few seconds, probably the fuel chucked down the carb. Next, I opened throttle fully and again blew down exhaust line expecting to see fuel going down carb venturi. Nothing!
I am wondering if the carb needle is actually moving with the barrel? :unsure: :angry:
Last edit: 02 Feb 2015 11:17 by Phil Ford.
  • ronp849
02 Feb 2015 12:06 #3710 by ronp849
Replied by ronp849 on topic ASP 120 4 str Not playing ball!
Hi Phil
I have had this happen several times and the problem was always hair strands in the carb and jets - these can be very difficult to see, even with a x9 eyeglass.
As a matter of course, I always strip the carb and blow out the jets with compressed air if an engine keeps cutting out unexpectedly.
Ron
02 Feb 2015 13:09 - 02 Feb 2015 13:12 #3711 by Phil Ford
I have stripped the carb down. With a piece of tubing I can't blow through the fuel nipple with the main jet holder in place. It appears to me that when the holder is in place it is blocking off the hole from the fuel inlet nipple. Hence when I try to blow through the nipple my face nearly explodes! Take it back out again and my face deflates.. :lol:
I am sure on my other carbs there was a thick fibre washer rather than a micro thin plastic washer! i am going to try spacing the main holder with a washer. Can't lose anything by it. New carb is £35 plus P&P so don't want to go down that route................. Yet!
Last edit: 02 Feb 2015 13:12 by Phil Ford.
02 Feb 2015 14:21 #3712 by DavidTappin
Replied by DavidTappin on topic ASP 120 4 str Not playing ball!
Maybe ASP is short for Aspirations: dictionary definition "a hope or ambition of achieving something".
02 Feb 2015 14:41 - 02 Feb 2015 14:42 #3713 by Phil Ford
Probably right David.
Carb refitted and engine on test bed. A few drops of fuel down exhaust (because the carb is upside down) Flick it over a bit to draw fuel in. Starts, runs for a few seconds and stops. Doesn't appear to be pulling fuel through the line. Yet if I blow down exhaust with the fuel line off fuel pours out (and getting wasted) Total time spent over last few days - 12 hours - so given up. I am gonna dig out the original two stroke, less hassle, went well although have to prime and start usually with model inverted.
I am considering sending it back to Just Engines, see what they say.
I don't think it's the make though - bought Chris73's 120 4str Asp which is in the Spitfire and no problems at all really.
Last edit: 02 Feb 2015 14:42 by Phil Ford.
02 Feb 2015 16:24 #3714 by Chris73
Replied by Chris73 on topic ASP 120 4 str Not playing ball!
- bought Chris73's 120 4str Asp which is in the Spitfire and no problems at all really.[/quote]
In that case the solution is simple, give me the engine and I will sell it back to you B)
Time to create page: 0.392 seconds
