ASP 120 4 str Not playing ball!
02 Feb 2015 17:49 - 02 Feb 2015 17:51 #3715 by Phil Ford
Replied by Phil Ford on topic ASP 120 4 str Not playing ball!
Chris73 wrote: - bought Chris73's 120 4str Asp which is in the Spitfire and no problems at all really.
In that case the solution is simple, give me the engine and I will sell it back to you B)
Okay. I'll give you what you paid for it after you fixed it - zilch! :lol:
Last edit: 02 Feb 2015 17:51 by Phil Ford.
05 Feb 2015 12:12 - 05 Feb 2015 12:15 #3735 by Phil Ford
A call to Just Engines solved it. The idle jet was wound right down (must have been a good party the night before down there in China) :(
So even with the throttle wide open the needle would not pull back far enough to let fuel in. I just new it had to be something simple, that's why I had not discovered it myself.... :lol:
Also. Andrew said that there are "no numbers for jet settings". Because there are so many variables around the world, humidity, altitude, temperature,etc , any setting given are starting points. The settings are what ever makes the engine run sweet! :)
Last edit: 05 Feb 2015 12:15 by Phil Ford.
Time to create page: 0.302 seconds
