Bearing removal help required
  • JonTappin
01 Feb 2015 16:38 #3690 by JonTappin
Bearing removal help required was created by JonTappin
Stripped the West 53 from the Curare down to replace the bearing, when removing the crankshaft, the bearing fell apart, leaving the outer ring in place and I can't get it out. Tried heating the crankcase and cooling the bearing but no joy, can't get hold of it with anything. Do any of you engineering types have any bright ideas or suitable tools for removal?
Pictures attached
01 Feb 2015 17:15 #3691 by Phil Ford
Replied by Phil Ford on topic Bearing removal help required
Oh dear Jon. Assuming there is a gap between the bearing case and the crankcase or an edge then I think you are in need of a bearing puller with outside grips. But for something that small, possibly a specialist tool. You have tried the obvious ideas. Can you see an edge from the other end that maybe a small parallel punch could get a tap on. But for something that small, possibly a specialist tool.
Maybe just engines could help
  • ronp849
01 Feb 2015 18:06 #3693 by ronp849
Replied by ronp849 on topic Bearing removal help required
Hi Jon
I assume it fell apart because the ball cage failed. If you have the bearing inner and balls, you could try reassembly without a cage.
Offset the inner to the outer and drop the balls into the gap generated. Then centralise the inner by pushing the balls around until they are equally spaced. Some bearings are assembled this way whereas others have to have their outers squeezed slightly to get all the balls in. (If assembly is difficult, you might get away with using one ball less.
regards
Ron
01 Feb 2015 18:39 #3694 by DavidTappin
Replied by DavidTappin on topic Bearing removal help required
Jon asked
I have a three legged puller but I think you knew that so maybe you don't believe there is enough exposed land to get hold of.
Note for Phil C, I know it should be "of which to get hold".
Dad
01 Feb 2015 19:06 - 01 Feb 2015 19:07 #3695 by Phil Ford
DavidTappin wrote: Jon asked
Dad
Will you two stop it..... :lol: Forget grammar, as long as the context is correct and we all know wot u meant who cares! :evil:
Last edit: 01 Feb 2015 19:07 by Phil Ford.
01 Feb 2015 20:32 #3698 by Dave Rogers
Replied by Dave Rogers on topic Bearing removal help required
Have you tried leaving the entire assembly in your oven for a good while then take it out and tap it a few times against work surface, likely to just pop out! I've done this before
  • JonTappin
01 Feb 2015 21:07 - 01 Feb 2015 21:09 #3699 by JonTappin
Replied by JonTappin on topic Bearing removal help required
Dad
No I didn't know you had a puller, but I don't know what it would get hold of, the only visible part of the outer surface of the bearing is a small area at the top which you can see in the picture taken from the top of the cylinder.
Dave Rogers wrote: Have you tried leaving the entire assembly in your oven for a good while then take it out and tap it a few times against work surface, likely to just pop out! I've done this before
First thing I did Dave, that's how I always get a bearing out, couldn't shift it at all :(
Last edit: 01 Feb 2015 21:09 by JonTappin.
01 Feb 2015 22:32 - 01 Feb 2015 22:52 #3701 by kevinross
Replied by kevinross on topic Bearing removal help required
If the previous suggestion of reassembly of the bearing is not successful then i would turn an alloy bar with the last 5mm rounded to the profile of the balls. which just fits the existing outer shell bore. Drill the centre approx 6mm. then make 2 saw longditudinal saw cuts at 90 deg to each other. Then drive a taper (centre punch into the approx 6mm bore to expand the profile into the bearing - Now you have something locked into the shell.
If this explanation doesn't make sense - I'll send you a sketch.
This attachment is hidden for guests.
Please log in or register to see it.
Last edit: 01 Feb 2015 22:52 by kevinross.
  • FrankRobinson
01 Feb 2015 22:47 #3702 by FrankRobinson
Replied by FrankRobinson on topic Bearing removal help required
Hi Jon, Drop it round to me, I have made all sorts of tools for jobs like this, a quick is stick it in the deep freeze for a couple of hours then just heat the casing near the bearing for a few seconds and give it a good bang on a piece of wood, but feel free to drop it round, regards Frank
  • JonTappin
02 Feb 2015 08:59 #3705 by JonTappin
Kevin
I understand the idea thanks, but don't have the facilties to make the tool.
FrankRobinson wrote: Hi Jon, Drop it round to me, I have made all sorts of tools for jobs like this, a quick is stick it in the deep freeze for a couple of hours then just heat the casing near the bearing for a few seconds and give it a good bang on a piece of wood, but feel free to drop it round, regards Frank
Thanks Frank, will give that a try, I have already tried the reverse, heating the crankcase and cooling the bearing but I will try this way. Otherwise I might be dropping round!
Time to create page: 0.474 seconds
