Bearing removal help required
17 Feb 2015 07:46 #3820 by DavidTappin
Replied by DavidTappin on topic Bearing removal help required
Job Done
David
The following user(s) said Thank You: JonTappin
18 Feb 2015 21:57 #3825 by 4Pedalsfly
Replied by 4Pedalsfly on topic Bearing removal help required
This may be of interest, there used to be a toolmaker in Verwood who, as a sideline offered a service removing stubbern
studs, bearings etc from vintage motor cycle engines.
They used Spark Erosion machines to good effect & in Jon's case this would leave a ring of very thin metal which could then be easily prised out.
Colin.A
  • FrankRobinson
19 Feb 2015 09:52 #3831 by FrankRobinson
Replied by FrankRobinson on topic Bearing removal help required
It was a very expensive way of doing it, a new engine would have been cheaper. It was only used when the casting or machined job had a lot of cost in it
Time to create page: 0.279 seconds
