Electric pump
15 Oct 2015 19:04 #6475 by flyingpete
Electric pump was created by flyingpete
Never had an electric fuel pump and don't fancy pumping 3ltrs of kero every flight into my panther with my H9 hand pump.
Looking for a simple pump which will fill and drain powered with a Lipo to use with my 25ltr Jerry can ?
15 Oct 2015 20:20 - 15 Oct 2015 20:22 #6483 by JonTappin
Replied by JonTappin on topic Electric pump
Pete
The Kavan pump seems pretty decent, I have one in my fuel caddy, runs forever on a 3 cell 2200 lipo, just needs forward and reverse switches. They can leak after a while but you can buy replacement gasket sets. I think Dave Wilshire at Motors and Rotors stocks them. Otherwise there are other fuel caddy options out there but they can get quite expensive.
Last edit: 15 Oct 2015 20:22 by JonTappin.
15 Oct 2015 20:22 #6484 by JonTappin
By the way, its about time you changed your avatar pic, that's my model!! :)
15 Oct 2015 20:41 #6493 by JRI
Replied by JRI on topic Electric pump
www.hobbyking.co.uk/hobbyking/store/__17..._Pump_Nitro_Gas.html
£4 1/2 smakeroonees, takes a while but gets there in the end. Gives me time to pump up the air bottles and do other checks while its filling!
15 Oct 2015 20:52 #6497 by flyingpete
Replied by flyingpete on topic Electric pump
JonTappin wrote: By the way, its about time you changed your avatar pic, that's my model!! :)
It's done!
15 Oct 2015 20:55 #6498 by flyingpete
JRI wrote: www.hobbyking.co.uk/hobbyking/store/__17..._Pump_Nitro_Gas.html
How long will it last?I could always buy a couple
15 Oct 2015 22:04 #6505 by JonTappin
It's done!
Replaced by a silhouette :( I was expecting a Panther!
  • Adrian
15 Oct 2015 22:32 #6507 by Adrian
Replied by Adrian on topic Electric pump
i have never managed to make a (glow fuel) pump last for very long so my money would be on the hobbyking one.
  • ronp849
15 Oct 2015 23:00 #6517 by ronp849
Replied by ronp849 on topic Electric pump
Could you use positive air pressure in the fuel bottle to drive the fuel into the tank. Likewise pressurise the fuel tank to empty it. (this would also highlight any leaks in the clunk to tank bulkhead tubing.)
Air pressure from standard tyre inflator.
16 Oct 2015 08:21 #6524 by JRI
It's just a simple geared pump with a brushed cheap dc motor. I guess it will last as long as the brushes. I have 4 in-line fuel filters of varying mesh which probably slows it down a bit - then again it isn't powerful enough to blow off any connectors.
Time to create page: 0.332 seconds
