Electric pump
  • Adrian
16 Oct 2015 09:13 #6526 by Adrian
Replied by Adrian on topic Electric pump
I like the idea of the air pressure especially as you have a compressor for the retracts anyway.
only concern is what pressure (if any) are those jerrycans rated for and what is their mode of failure? will it just spring a leak or will it tear and fail suddenly with a large amount of highly flammable liquid floating around?
  • ronp849
16 Oct 2015 09:43 - 16 Oct 2015 09:56 #6530 by ronp849
Replied by ronp849 on topic Electric pump
This was not my original idea - My son used it for filling wing tanks with petrol on his FoxKit plane. (Full size). With the jerrycan on the ground, he generated a 7ft head with no ill effect.
The pump was a mains driven air pump intended for a Koi fish pond.
Just Googled the idea - Search for Polarn Pump.
Last edit: 16 Oct 2015 09:56 by ronp849.
16 Oct 2015 10:52 #6531 by Chris73
Replied by Chris73 on topic Electric pump
I have been using the Kavan pump in my fuel can for about a year now without any issues (I know i shouldn't have said that :dry: )
Even if the seals do start leaking they are only a few pounds for a complete set, i was advised to run the pump in reverse at the end of the flying sessions so there is no fuel left in the pump, seems to have worked so far :)
16 Oct 2015 13:18 #6537 by MikeSeale
Replied by MikeSeale on topic Electric pump
Re. using air pressure to fill a tank...
I know this is being asked in terms of pumping kerosene, but would remind people of the dangers of methanol in your eyes...it can cause blindness. I do not know whether kerosene or petrol have similar hazards. The risk of a pressurised tank surely cannot be worth considering when we have conventional pumps available, even if they do need a little maintenance from time to time?
  • ronp849
16 Oct 2015 14:43 #6538 by ronp849
MikeSeale wrote: Re. using air pressure to fill a tank...
Hi Mike - I agree with the dangers of methanol but I would think the output pressure of a standard motorised pump would be far greater than that of a pressurised tank. The pressure generated by a fuel pump would be uncontrolled and unknown so the possibility of a fuel line popping off an inline filter or filling adaptor would be greater. The flow rate from the Jerrycan would be increased by using a larger bore tube which would allow a low air pressure to be used.
16 Oct 2015 16:35 #6540 by MikeSeale
I've said my piece and do not intend trying to justify the advice offered
16 Oct 2015 20:39 - 16 Oct 2015 20:42 #6546 by flyingpete
Replied by flyingpete on topic Electric pump
Thanks guy's for your input B) I won't be using air pressure as the retracts are electric
Last edit: 16 Oct 2015 20:42 by flyingpete.
  • FrankRobinson
21 Oct 2015 11:59 #6634 by FrankRobinson
Replied by FrankRobinson on topic Electric pump
Hi GUYS, Just like to point out that any pressurzed vessel used in a public place (with fuel) requires a test cert and must be tested to 21/2 times working pressure first time then 11/2 times every year, you will need some body like me with the paperwork to test these or a outside person which could cost, if its steel every year, copper every 2 years think about it :ohmy:
  • ronp849
21 Oct 2015 14:39 #6639 by ronp849
Hi Frank
So it looks like scratch the pressurised Jerry-can idea then!!
BTW - What constitutes a 'pressurised vessel'. Would that include the 'pressurised fuel tank on most if not all glow powered models? :whistle: :silly:
  • FrankRobinson
21 Oct 2015 19:26 #6649 by FrankRobinson
Hi Ron your on board fuel tank is open through the exhaust fitting so any over pressure would escape through that, also the areas and volume are very small a jerry can a bit larger, a coca cola can can stand well over 100psi (8bar) to the young ones but the shape becomes differant :silly:
Time to create page: 0.336 seconds
