Pat teakle 6metre glider
  • christopher
07 Jul 2014 18:32 #2343 by christopher
Pat teakle 6metre glider was created by christopher
Hi I purchased (at great expense £75) a pat teakle glider unbuilt which I believe to be an asw22 wing span 6 metres which works out at 19 feet 6 inches in real money and by the time the fuselage and tips are included it will be 20 feet. I have also managed to obtain a DVD 60 minutes with pat teakle in which he shows building one of his gliders, so armed with this information I am starting to build this week end. I will be taking pictures shortly and adding them.
08 Jul 2014 17:30 #2361 by 4Pedalsfly
Replied by 4Pedalsfly on topic Pat teakle 6metre glider
Chris - Look forward to seeing your build pics, what a bargain at £75.0
I have the Graupner ASW 22B - a baby at 2.7m compared to yours.
Will this be flown off the slope or will you need the services of a glider tug.
Colin.A.
  • christopher
08 Jul 2014 17:45 #2362 by christopher
Replied by christopher on topic Pat teakle 6metre glider
I will hope to slope it but I will be fitting a releasable tow hook so it can be towed when I'm brave enough. here are some photos of my purchase. to give some scale the steel rule is 1 metre. 4 wing panels with leading edge, tail plane, rudder, all made from foam veneered, cockpit flooring, the fus made from fibreglass, and a set of air brakes, which I feel maybe on the small side
  • christopher
08 Jul 2014 17:46 #2363 by christopher
  • christopher
08 Jul 2014 17:47 #2364 by christopher
  • christopher
10 Jul 2014 17:28 #2376 by christopher
leading edge on and aileron extension lead in place
  • christopher
16 Jul 2014 17:58 - 16 Jul 2014 19:18 #2421 by christopher
basic wing construction completed a little bit bigger than I first thought. no ailerons or flaps or airbrakes yet,
[IMG
Last edit: 16 Jul 2014 19:18 by MikeSeale. Reason: Rotated image to ease neck muscles
16 Jul 2014 19:19 #2422 by MikeSeale
Replied by MikeSeale on topic Pat teakle 6metre glider
Looking good, Chris. I hope you don't mind, but I rotated the image for you.
  • christopher
31 Jul 2014 20:56 - 31 Jul 2014 21:02 #2678 by christopher
tail plane and rudder ready for fibre glassing
Last edit: 31 Jul 2014 21:02 by christopher.
  • christopher
02 Aug 2014 13:54 #2690 by christopher
The photo seems to have done a runner I will try and post it again
Time to create page: 0.403 seconds
