Wire Bending
8 years 11 months ago #10453 by Phil Ford
Wire Bending was created by Phil Ford
Is there anywhere local that supplies and bends 4 gauge (5.2mm) steel wire? I have spoken to SLEC regarding Chipmunk but they are extremely busy at present and cannot guarantee when Chris can make me up another set of gear.
I have got a new set for from the Pepsi to act as a pattern/template because the angles need to be spot on.
8 years 11 months ago #10456 by John Bannister
Replied by John Bannister on topic Wire Bending
Phi, Probuild say they have 7/32 piano wire on there website I can probably bend it for you, get two lengths.
8 years 11 months ago #10458 by Phil Ford
Replied by Phil Ford on topic Wire Bending
Thanks for the info John. 7/32 = 5.55 whereas the original 4 gauge = 5.189 (round it up to 5.2mm). The latter wire fits very neatly in the wing gear sockets already so really want to avoid drilling out a tiny bit more. However, 7/32 may be a fallback plan.
Tried bending this wire before in a vice - it doesn't work very well. Really need the proper bending tool for those sharp right angles too.
8 years 11 months ago #10460 by 4Pedalsfly
Replied by 4Pedalsfly on topic Wire Bending
Phil - Maybe worth putting an enquiry on the BMFA site, some scale types probably have
the kit for wire bending. Not sure at what point Wire becomes Rod.
8 years 11 months ago #10463 by Phil Ford
Have spoken again to SLEC and can confirm that the wire they use is 6mm. Why the first Guy I spoke to got 4 gauge from dunno?
8 years 11 months ago #10466 by DavidTappin
Replied by DavidTappin on topic Wire Bending
4 swg (Standard Wire Gauge) is 5.89mm diameter.
Maybe that's where the guy at SLEC got it from Phil!
Time to create page: 0.256 seconds
