Oleo Help
04 Nov 2016 10:29 #10558 by Phil Ford
Oleo Help was created by Phil Ford
Discovered some oleos in my "parts store" aka "did not know I had them" that are better quality than the ones that I put on Pennzoil Chipmunk. The latter used 3mm screws in loose guides which gave the wheels alternating toe-in, toe out. The discovered ones were, I believe machined down by David T a few years a go. Cannot remember where I purchased them from either. They use 4mm grub screws and slide in the guides much, much better.
What I need help with is to drill accurately/centrally some 6mm bores in the tops 15mm down from the first ridge. Maybe take off the top stump if necessary.
04 Nov 2016 11:49 #10559 by flyingpete
Replied by flyingpete on topic Oleo Help
Iv just drilled Dave's nose leg on the venom using my pillar drill very easy to do Phil!!
04 Nov 2016 12:38 #10561 by Phil Ford
Replied by Phil Ford on topic Oleo Help
Yes, easy to do if you have a pillar drill or lathe, Pete. I have neither. Why, I still use a hand drill and bit for everything..... ;)
04 Nov 2016 14:18 - 04 Nov 2016 14:19 #10562 by MikeSeale
Replied by MikeSeale on topic Oleo Help
When it comes to essential power tools, my number one would be a Dremmel (or similar) and next is a pillar drill. Mine's a bottom of the range B&Q one that has served me well for years. If you bought fewer models, Phil, you've have plenty of cash to buy one and space to house it too :P
Last edit: 04 Nov 2016 14:19 by MikeSeale.
04 Nov 2016 14:23 #10564 by Dave Rogers
Replied by Dave Rogers on topic Oleo Help
Yer Phil stop buying junk! :) :) :)
04 Nov 2016 14:46 #10565 by DavidTappin
Replied by DavidTappin on topic Oleo Help
Phil, If nobody else has already been awarded the contract to fix your legs bring them to Cashmoor tomorrow and I'll do them for you.
04 Nov 2016 15:15 #10567 by DaveBright
Replied by DaveBright on topic Oleo Help
David's leg work is very good....
04 Nov 2016 15:18 #10568 by DaveBright
04 Nov 2016 16:12 #10571 by JonTappin
Replied by JonTappin on topic Oleo Help
I would buy a proper one Dave, like Mike said it's such a useful tool and is a purchase you won't regret, mine gets used a lot, had it for years
04 Nov 2016 16:25 - 04 Nov 2016 16:27 #10572 by Phil Ford
DavidTappin wrote: Phil, If nobody else has already been awarded the contract to fix your legs bring them to Cashmoor tomorrow and I'll do them for you.
Thank you David. :)
Guys, appreciate your comments and quite agree that it must be one of the most useful tools ever. But never needed one before because I had access to drill presses, sheet metal cutters, grinders, etc in my previous employments. If you buy cheap Asian imports there is every likelyhood of movement of the quill therefore making holes slightly bigger than the drill bit. Anyway cannot warrant the outlay for what is an experiment/trial ;) and no room to hide it..
Dave Rogers wrote: Yer Phil stop buying junk! :) :) :)
:lol: :lol: That's rich! You should know!
At least I sold you a decent model. :whistle:
Last edit: 04 Nov 2016 16:27 by Phil Ford.
Time to create page: 0.406 seconds
