Petrol Fuel Can
23 Mar 2015 14:17 - 23 Mar 2015 14:18 #4068 by Phil Ford
Petrol Fuel Can was created by Phil Ford
Just purchased a Red 10 ltr plastic petrol can. Before I start drilling holes into the cap for fill and drain (which by design isn't gonna be simple) has anyone got some alternative solution. Nothing on this side of the big pond appears to be available. :( Cheers.
Last edit: 23 Mar 2015 14:18 by Phil Ford.
23 Mar 2015 17:47 #4072 by Dante
Replied by Dante on topic Petrol Fuel Can
PhilF51 wrote: Just purchased a Red 10 ltr plastic petrol can. Before I start drilling holes into the cap for fill and drain (which by design isn't gonna be simple) has anyone got some alternative solution. Nothing on this side of the big pond appears to be available. :( Cheers.
Well Phil funny you should say this but there is a solution. In the March issue of RCM&E there is a new cap with all the necessary cone actions fitted. Try the following URL and you could be the proud owner of the first purposed made feeling cap in the Club. Personally I'm waiting for the release of the complete feeling system in the hopefully near future.
23 Mar 2015 23:56 #4077 by 4Pedalsfly
Replied by 4Pedalsfly on topic Petrol Fuel Can
Look forward to seeing Phil wearing his "Feeling Cap ". - perhaps he will start a new trend.
Colin.A
  • Phil-C
27 Mar 2015 11:33 #4097 by Phil-C
Replied by Phil-C on topic Petrol Fuel Can
Born in Italy...
28 Mar 2015 07:09 - 28 Mar 2015 07:13 #4107 by Phil Ford
Replied by Phil Ford on topic Petrol Fuel Can
So, what are you petrol heads using? Jon appears to have an electric pump system, Steve M, I believe has a squeeze pump effort. What ever idea being used the can has to be sealed when not in use or likely to leak if toppled over.
I think I may be able to work around this issue. Instead of a two line system like I use for my glow fuel, I'll use just one tube and just slacken off the cap a little to let air in as the fuel level goes down.
Colin.A
If I do wear it there'll be no naked lights near me please otherwise it will singe my hair and eyebrows... :lol:
Last edit: 28 Mar 2015 07:13 by Phil Ford.
28 Mar 2015 10:12 #4110 by DaveBright
Replied by DaveBright on topic Petrol Fuel Can
Will take a photo of my simple setup later Phil. You should have a vent line as unscrewing a cap each time will get tedious.
I have a 10L can, two barb can fittings, a hangar 9 pump and a filter clunk.
One thing is that on the larger models..... An electric pump saves time and effort.
28 Mar 2015 17:23 - 28 Mar 2015 17:27 #4111 by AlanF
Replied by AlanF on topic Petrol Fuel Can
PhilF51 wrote: So, what are you petrol heads using? Jon appears to have an electric pump system, Steve M, I believe has a squeeze pump effort. What ever idea being used the can has to be sealed when not in use or likely to leak if toppled over.
Phil, I use an old 1/2 gallon glow container with Dubro cap fittings arranged such that the fill line also plugs into the vent fitting when not in use thus sealing the container. The container will then vent normally when the fill line is connected to the model. I use a Prolux hand pump which is ok for glow or gas and contains some useful tube fittings as well ( don't use the supplied silicon tubing as I'm sure you are aware).
I should add that this system isn't fully spill proof and the container is always transported in a field box.
Last edit: 28 Mar 2015 17:27 by AlanF.
28 Mar 2015 19:56 - 28 Mar 2015 20:34 #4112 by DaveBright
Here you are...
Last edit: 28 Mar 2015 20:34 by Unnamed user.
29 Mar 2015 11:03 #4113 by Phil Ford
Thanks Dave for those images. The problem with my cap is it isn't flat top like yours, it has a centre pin on top to accommodate the flexible fuelling spout when not in use and around the rest some raised ridges. I may have to grind these ridges off at the very least. If I don't get it right first time then the cap and can are scrap. I'll see if I can upload an image shortly to explain it more when it stops raining and I can get into the garage (hangar).
29 Mar 2015 11:17 #4114 by DaveBright
I know what you're talking about Phil - I ground mine flat.
Time to create page: 0.522 seconds
