Petrol Fuel Can
29 Mar 2015 12:11 - 29 Mar 2015 13:18 #4115 by JonTappin
Replied by JonTappin on topic Petrol Fuel Can
Phil
I'm using a DS fuel caddy which is no longer available, you could make something similar though, it uses a Kavan pump and a 3s lipo, I think the pumps are about 50 quid.
pipework in and out is through the bottle rather than the cap, using Festo fittings which allow the pipe to be easily connected and disconnected
Last edit: 29 Mar 2015 13:18 by JonTappin. Reason: added photo
29 Mar 2015 15:27 - 29 Mar 2015 15:29 #4118 by Phil Ford
Replied by Phil Ford on topic Petrol Fuel Can
Thanks for that image Jon, typical that when a good idea is created it never get carried on forward. There are some pumps on the market with a built in LiPo for gas and/or glow. They are designed to be screwed to a piece of ply for instance and then strapped to the can. Looking at your fittings, do these expand when you do the outside nut up. Obviously you cannot access a nut from the inside.
Last edit: 29 Mar 2015 15:29 by Phil Ford.
29 Mar 2015 16:33 #4124 by DaveBright
Replied by DaveBright on topic Petrol Fuel Can
I think DS Caddys were probably setup as an alternative to the jersey modeller systems.....?
www.modellbauuk.com/petrol-187-c.asp
Does seem a little pricey but you get what you pay for..
29 Mar 2015 17:12 #4130 by flyingpete
Replied by flyingpete on topic Petrol Fuel Can
There used to be a guy on highalpha forum who made up fuel caddy's, can't remember his name
29 Mar 2015 17:52 - 29 Mar 2015 17:54 #4132 by JonTappin
flyingpete wrote: There used to be a guy on highalpha forum who made up fuel caddy's, can't remember his name
That's where mine came from, he stopped making them. The one I have used a plastic box which isn't petrol proof so melts when the pump leaks, which Kavans all eventually do! Just replaced the gaskets in mine which sorts the problem. I heard he had a few complaints probably for this reason, so gave it all up. It wouldn't be difficult to make your own though.
PhilF51 wrote: Thanks for that image Jon, typical that when a good idea is created it never get carried on forward. There are some pumps on the market with a built in LiPo for gas and/or glow. They are designed to be screwed to a piece of ply for instance and then strapped to the can. Looking at your fittings, do these expand when you do the outside nut up. Obviously you cannot access a nut from the inside.
I think the fitting with tube and clunk attached is fitted from the inside then a nut fitted to the outside, fiddly but doable.
Last edit: 29 Mar 2015 17:54 by JonTappin.
29 Mar 2015 21:54 #4136 by kevinross
Replied by kevinross on topic Petrol Fuel Can
The marine / outboard engine fuel tanks might offer a suitable source of non spill storage for petrol. the tank in this advert coupled with a marine priming pump. Thats what my original Du bro container uses and still going strong since 1995.
www.gumtree.com/p/boats-kayaks-jet-skis/...fuel-tank/1106621159
www.ebay.co.uk/itm/like/161621244991?lim...3=80&ff14=108&ff19=0
30 Mar 2015 09:53 - 30 Mar 2015 09:59 #4139 by Phil Ford
Whooo! Thanks for that suggestion Kevin. Now that is just the job, why didn't I think of that? :S Many have integral fuel gauge too! A trip down to my local marine outboard shop then...
Last edit: 30 Mar 2015 09:59 by Phil Ford.
