Durafly sea Vixen
  • Andyf
27 Dec 2013 20:24 - 02 Jan 2014 08:46 #930 by Andyf
Durafly sea Vixen was created by Andyf
I am thinking of this durafly Sea Vixen from Hobbyzone has any one any experience or thoughts about this type of model
i really like planes with retracts and think it may need them swapping out for eflight retracts as Phil has done on his P51 i can live with that but would the wheels run on the grass at cashmoor
Andy
Specs:
Wingspan: 1000mm
Length: 888mm
Flying Weight: 1500g
EDF: 70mm with 2950kv 2836 Brushless Outrunner Motor
ESC: 45A w/UBEC
Plug Type: XT60
Servo: 9g x 4
Retracts: Servoless Electronic Type
Last edit: 02 Jan 2014 08:46 by Phil Ford.
27 Dec 2013 20:48 #932 by MikeSeale
Replied by MikeSeale on topic Durafly sea Vixen
Link?
27 Dec 2013 20:53 #933 by Phil Ford
Replied by Phil Ford on topic Durafly sea Vixen
www.hobbyking.co.uk/hobbyking/store/__28...eh0bsCFRLMtAodVHkA9A
Andy, Eflite 15 -25 tricycle are about the same price as the model, £100. The OEM retracts will be plastic also so see how goes first. Wheels are approx 25mm so short dry grass should not be a problem. Roger Scott's larger Delta EDF has rolled out okay numerous times. (Although in November we had to hand mow the centre of the field for it)
  • Stuartmck
28 Dec 2013 09:49 #939 by Stuartmck
Replied by Stuartmck on topic Durafly sea Vixen
I have the Vampire, similar size. Not yet flown. Although it has retracts, I will be hand launching and landing without the gear down. Spoke to a visitor to our scale day, he was flying same model, he stated that there is not enough power to take off on grass. Also,changing retracts will not help the mtg in foam, which, IMO, would be the weakness. Having said that, the visiting Vampire flew very well. Hope this helps.
Stuart
  • Andyf
28 Dec 2013 10:12 #940 by Andyf
Replied by Andyf on topic Durafly sea Vixen
Sorry Mike
i don't know how to attach the link for the model just seems to come up as text
www.hobbyking.co.uk/hobbyking/store/catalog/seavixen-main.jpg
Andy
  • Andyf
28 Dec 2013 10:16 #941 by Andyf
  • Andyf
31 Dec 2013 09:27 #962 by Andyf
Thanks i will bear in mind, i have a similar problem with a T28 cant make take off speed on grass( it seems common with tricycle gear) i converted it to a tail dragger now its ok ,not really an option for vixen
Andy
01 Jan 2014 22:02 #1001 by 4Pedalsfly
Replied by 4Pedalsfly on topic Durafly sea Vixen
Stuart - Re the HobbyKing Vampire - I've seen one of these flown regulary.
Maiden flight was attempted off short grass but it just sat there making a whinning sound
and going nowhere.
Goes off o.k from a hand launch but having a fatish body is not an easy launch, best done by a friend.
With this model it would appear the best option is to save some weight by removing the retractable undercarriage
and settle for hand launching.
Colin.A
  • Andyf
02 Jan 2014 11:44 #1003 by Andyf
Thanks for that, Colin i must think on.
Andy
  • Stuartmck
02 Jan 2014 15:19 #1006 by Stuartmck
I know the one you mean. I intend leaving the u/c in position as, having the wells filled in makes the model more difficult to launch. I spoke about it at scale day.
Stuart
Time to create page: 0.369 seconds
