Winter build threads
25 Oct 2016 16:14 #10430 by MikeSeale
Replied by MikeSeale on topic Winter build threads
Chris001 wrote: you've only got to watch Mike with his Bubble Dancer to appreciate just how stressful that type of flying is!
The stress happens in a strong thermal at 500m when you start to ask yourself "how strong is that spar?"
25 Oct 2016 16:37 - 25 Oct 2016 17:15 #10431 by Phil Ford
Replied by Phil Ford on topic Winter build threads
flyingpete wrote: It will be built around my Wren 100 B)
Hunter lost out on the turbine? ;)
If I feel like trying my patience to the limit then this may get some attention............A Carl Goldberg from Ebay
Last edit: 25 Oct 2016 17:15 by Phil Ford.
27 Oct 2016 15:35 #10461 by Brian
Replied by Brian on topic Winter build threads
Hi Pete, here's a couple of shaky pics of the Giles' engine mounting box. The pencil lines are square to the centre line of the fuselage..
Regards.
Brian
27 Oct 2016 17:26 #10462 by JonTappin
Replied by JonTappin on topic Winter build threads
Hi Brian
The side thrust is built into the front bulkhead, which is common practice. You need to calculate or measure how much off centre the prop driver is horizontally and vertically, then off set the holes in the bulkhead for the mounting bolts by the same dimension. As long as the bulkhead is wide enough to allow for this then this will resolve your issue.
See my rubbish sketch below, I have exagerated the side thrust to try to make it clearer. Hope this helps
27 Oct 2016 18:38 #10465 by MikeSeale
What CAD package did you use, Jon?
27 Oct 2016 18:45 #10468 by DavidTappin
Replied by DavidTappin on topic Winter build threads
Complete Amateur Drafting package?
27 Oct 2016 18:50 #10471 by JonTappin
Etch a sketch 2016 :)
27 Oct 2016 18:52 #10472 by Phil Ford
JonTappin wrote: Etch a sketch 2016 :)
Is that the one where you shake it and the sketch disappears? :lol:
27 Oct 2016 22:59 #10477 by Brian
I think the sketch is not only helpful, its original, and I'm going to print it and hang it over my workbench.
28 Oct 2016 08:46 #10479 by JonTappin
Brian wrote: I think the sketch is not only helpful, its original, and I'm going to print it and hang it over my workbench.
Glad it has helped, do you want me to sign it for you :lol:
Time to create page: 0.668 seconds
