Winter build threads
8 years 10 months ago #10461 by Brian
Replied by Brian on topic Winter build threads
Hi Pete, here's a couple of shaky pics of the Giles' engine mounting box. The pencil lines are square to the centre line of the fuselage..
Regards.
Brian
8 years 10 months ago #10462 by JonTappin
Replied by JonTappin on topic Winter build threads
Hi Brian
The side thrust is built into the front bulkhead, which is common practice. You need to calculate or measure how much off centre the prop driver is horizontally and vertically, then off set the holes in the bulkhead for the mounting bolts by the same dimension. As long as the bulkhead is wide enough to allow for this then this will resolve your issue.
See my rubbish sketch below, I have exagerated the side thrust to try to make it clearer. Hope this helps
8 years 10 months ago #10465 by MikeSeale
Replied by MikeSeale on topic Winter build threads
What CAD package did you use, Jon?
8 years 10 months ago #10468 by DavidTappin
Replied by DavidTappin on topic Winter build threads
Complete Amateur Drafting package?
8 years 10 months ago #10471 by JonTappin
Etch a sketch 2016 :)
8 years 10 months ago #10472 by Phil Ford
Replied by Phil Ford on topic Winter build threads
JonTappin wrote: Etch a sketch 2016 :)
Is that the one where you shake it and the sketch disappears? :lol:
