F15 Build
31 Oct 2016 19:34 #10524 by simondean
Replied by simondean on topic F15 Build
Does anyone do a kit of the F14 ? Can't remember seeing a model version. Also what's the handling from grass strip likely to be ? Simular to the F15 ?
31 Oct 2016 21:40 #10528 by Dave Rogers
Replied by Dave Rogers on topic F15 Build
Pete, you'll be finished in no time at this rate, impressed yet again.
Perhaps I will have to commission you to do my f15, if your interested?
Dave... lovely mustang in the background of that picture :)
31 Oct 2016 21:57 - 31 Oct 2016 22:00 #10529 by DaveBright
Replied by DaveBright on topic F15 Build
simondean wrote: Does anyone do a kit of the F14 ? Can't remember seeing a model version. Also what's the handling from grass strip likely to be ? Simular to the F15 ?
Probably better ground handling as wider track undercarriage and trailing link oleos.... F15 with narrow track and high fins can get a bit buffetted in a strong cross wind.
www.skymasterjet.com/f14.htm
www.jethangar.com
www.hobbybarn.com/f-14-tomcat-twin-ducted-fan-detailed-plans
Last edit: 31 Oct 2016 22:00 by DaveBright.
31 Oct 2016 21:58 #10530 by Dave Rogers
Get it Simon :) just do it !
31 Oct 2016 22:00 #10531 by JonTappin
Replied by JonTappin on topic F15 Build
There are a few F14 kits, not that common though because of the swing wing. Handling would be good with the wings forward, tricky with them swept!
01 Nov 2016 08:48 #10532 by DaveBright
01 Nov 2016 16:52 #10535 by Phil Ford
Replied by Phil Ford on topic F15 Build
DaveBright wrote: www.motionrc.com/collections/freewing-rc...win-80mm-edf-jet-pnp
Now...back to the F15 build :)
Yes, no diverting the subject. :lol:
01 Nov 2016 21:11 #10539 by flyingpete
Replied by flyingpete on topic F15 Build
Dave Rogers wrote: Pete, you'll be finished in no time at this rate, impressed yet again.
Not a problem Dave
03 Nov 2016 20:44 #10554 by flyingpete
The tailerons/elevators have been glassed and a coat of primer.Just leaves the wings to finish and glass the fins and she is done ready to fit out as and when but not in any rush.
04 Nov 2016 17:06 - 04 Nov 2016 17:06 #10575 by Phil Ford
Looking good Pete. Swinging on bearing supported shaft?
You must have a nice warm workshop to be busy in. :) My work area is affected by rain at the moment. ;)
Last edit: 04 Nov 2016 17:06 by Phil Ford.
