BVM Mig.15
8 years 4 months ago #12634 by flyingpete
The office
8 years 4 months ago #12635 by JonTappin
Replied by JonTappin on topic BVM Mig.15
Lovely!
8 years 4 months ago #12636 by 4Pedalsfly
Replied by 4Pedalsfly on topic BVM Mig.15
Pete - Cockpit detail looks most impressive, is there much more work to do ?
8 years 4 months ago #12637 by flyingpete
Basically Colin the mig is a giant airfix kit where every part needs some fine fettling, and in a lot of cases painting, so it's nothing like the ARTF's most people are used to and therefore very time consuming and the build hours soon go into 100's. Next job is to install the air system's for retracts and brakes and hook up to the various rams etc. Next will be to install the rest of the servos and make up the servo leads and to the correct length and hand crimp the plug and sockets. Re- install the turbine, fit the bubble trap and connect up the fuel lines. Finally I will go through my work checking everything and when happy hand it back to John.
8 years 4 months ago #12639 by Phil Ford
:woohoo: A fine job Pete. ;) All though with Airfix seemed to always get glue fingerprints on the smoothest pieces........:(
8 years 4 months ago #12640 by flyingpete
The trick is to make sure you have a debonder/solvent like isopropyl alcohol to hand at all times.
Time to create page: 0.355 seconds
