Begin' Acro Glider
15 Oct 2017 20:47 #14211 by MikeSeale
Glue the dowel in the canopy leaving a hole in the former. That way you'll be able to see the dowel lining up with the hole.
15 Oct 2017 21:01 #14213 by Chris001
Thanks Mike.
Motor fits :whistle:
15 Oct 2017 23:17 - 15 Oct 2017 23:21 #14219 by JonTappin
Replied by JonTappin on topic Begin' Acro Glider
Chris001 wrote: The trailing edge of the tail plane is one piece and the elevator is one piece, yet some how they have managed, with great precision, to make the elevator 2mm too short!
Chris
Firstly let me say that you worry too much :)
Secondly, can I suggest a solution.
Face both ends of the elevator with 1mm ply, this will not only make up the shortfall, but provide an elevator tip that's far more resistant to damage.
2 birds, 1 stone!
If you feel you need to increase my karma rating for this, that's fine ;)
Last edit: 15 Oct 2017 23:21 by JonTappin.
16 Oct 2017 07:48 #14223 by Chris001
JonTappin wrote: If you feel you need to increase my karma rating for this, that's fine ;)
Done, but you realise it's now six hours before I can drop Chris 73's Karma again :evil:
But yes, I do worry too much!
16 Oct 2017 12:14 - 16 Oct 2017 12:15 #14226 by Phil Ford
Replied by Phil Ford on topic Begin' Acro Glider
How in heaven and earth did Gromit manage to get MINUS -43 Karma? Could this be a record?
Last edit: 16 Oct 2017 12:15 by Phil Ford.
16 Oct 2017 12:30 #14227 by Chris001
Hi Phil, might I direct you to my post of August 19th: wimbornemac.org/forum/roll-calls/1361-sa...ay-19th-august#13562
:evil:
16 Oct 2017 14:01 #14228 by Chris73
Replied by Chris73 on topic Begin' Acro Glider
[/quote]Done, but you realise it's now six hours before I can drop Chris 73's Karma again :evil:[/quote]
Unbelievable, your really not trying very hard Chris, only down to -10!!
I am insulted that you are putting in so little effort at reducing my karma
16 Oct 2017 17:29 - 16 Oct 2017 17:31 #14229 by Phil Ford
Chris001 wrote: Hi Phil, might I direct you to my post of August 19th: wimbornemac.org/forum/roll-calls/1361-sa...ay-19th-august#13562 :evil:
It beggars belief that you have made so much effort to become the highest "Negative" on this Forum. I am not sure whether it is a record as there is no way of checking. Maybe, just maybe could you as much effort towards "Positive" just a little? :lol:
As a footnote I have been 5 since the beginning of time :huh: , I think it might be stuck.
Last edit: 16 Oct 2017 17:31 by Phil Ford.
23 Oct 2017 23:14 #14357 by Chris001
I was about to write a lengthy and well documented update about, in no particular order, the twists and turns of my aileron endeavours, a leading edge profile jig, fitting of the snakes, and the inner turmoil I'm currently going though to decided whether to make it a pure sloper, or continue with my original plan to make it an electric glider... But then I remembered a remark that cut to the bone, and from someone who I was just developing the merest hint of respect for :huh: :
JonTappin wrote: Great progress Pete.
This is like an antidote to a Chris001 build thread ; )
It appears taking 10 months to put together a laser cut kit glider is just not fast enough for some ;)
24 Oct 2017 08:10 #14359 by Chris73
Do you want me to finish it for you Chris :lol: :lol: :P
Time to create page: 0.464 seconds
