How do you go about designing an aircraft?
10 Jan 2017 16:10 #11495 by kevinross
Replied by kevinross on topic How do you go about designing an aircraft?
Another contribution to your list of publications - written by Martyn Pressnell, a member of my local Christchurch model club who sadly was lost to the dreaded C last week. He only published the book last year.
www.amazon.co.uk/Model-Planes-Aerofoils-...ssnell/dp/0719815401
I understand there is a copy in the the C&Dmfc library which i could borrow for a few weeks should it be of interest.
10 Jan 2017 17:11 #11496 by MikeSeale
Replied by MikeSeale on topic How do you go about designing an aircraft?
A lot of models and full-sized planes are the shape that they are because of trial and error. There is also a lot of copying a proven design so they all look similar if they are designed to do the same job. And finally, there is a lot of trends that serve no purpose but everyone wants to have the latest watchamacallit because that's what Walter is flying.
Google 'luft 46' to see what is possible when you start with an open mind instead of copying others
10 Jan 2017 17:31 #11497 by MikeSeale
Aerofoil sections follow trends too. Prior to computers, people sketched out a shape using the TLAR principle. But nowadays it is possible to design foils to meet certain design criteria. You'll need to understand how to interpret 'polars' in order to understand how different aerofoils will behave in terms of lift and drag at different angles of attack. When you understand the polar you will begin to see why one aerofoil might be better than another in some conditions but the opposite might be true when the conditions change.
You might want to google the following...depending how deep you want to delve!
Dr Mark Drela
UIUC Airfoil data site
Airfoil tools
xfoil
Selig/Donovan
Dr Helmut Quabeck
10 Jan 2017 17:43 #11498 by MikeSeale
And to answer a couple of your original questions...
Yes, NACA aerofoils are referring to the NACA that became NASA.
HQW 1/8 Mod is a Helmut Quabeck section that has 1% camber and is 8% thick. His earlier sections were named HQ 1/8, for example, and their coordinates are freely available to download. With the advent of PC's and aerofoil plotting software, he realised that there was money to be made and tweaked these sections and added the W to their description. The coordinates of the W series of aerofoils can only be had it you pay for them.
The Mod is a phrase just means it's been modified. The designer will rarely say how it is modified and sometimes it just means "by the time you've finished building and sanding, it will be modified".
10 Jan 2017 18:19 - 10 Jan 2017 18:20 #11500 by Phil Ford
Replied by Phil Ford on topic How do you go about designing an aircraft?
Chris001 wrote: none of that fuel mellarky ;)
Now either you meant to write "malarky" (noun: = meaningless talk; nonsense) or intended to write smellarky. :unsure: As your a sworn and dedicated electron burner I would suggest the latter. :)
Either way you are digging into a minefield of printed data and in the end you get "brain overload" and it will just give up. How do I know? Been there when getting into( or trying to) understand Linux code for Apache servers. :( many years ago
Last edit: 10 Jan 2017 18:20 by Phil Ford.
12 Jan 2017 10:21 #11521 by 4Pedalsfly
Replied by 4Pedalsfly on topic How do you go about designing an aircraft?
Chris - Going back to our earlier discussions:
The models I designed were control line combat models in the late 50s
and early 60s & were my variations of existing designs.
I have dug out 4 model books published between 1960 & 1980 which you will enjoy
browsing through. Articles on basic design, how to get started and model aerodynamics are among
the many subjects covered.
I will box them up & leave them in the hut for you next time I go to Cashmoor.
12 Jan 2017 20:40 #11522 by Chris001
Replied by Chris001 on topic How do you go about designing an aircraft?
Hi Colin, that's really kind of you, thank you so much. I'm sure there will be loads in them to help me understand some of the principles of aerodynamics and aircraft design.
Chris
18 Jan 2017 21:11 #11597 by Chris001
Martin Simons book arrived today, a light read it is not :cheer: But that was what I'd hoped for, and I am expecting to have to put some work in to understand it. I just wish I'd paid attention in my physics and maths classes :pinch:
Time to create page: 0.313 seconds
