3D Printed Models
  • DavidTappin
02 Mar 2017 10:15 #12117 by DavidTappin
3D Printed Models was created by DavidTappin
Whatever next?
A see-trough P38 for less than $20 worth of material - who's got a 3D printer and wants to have a go at this?
02 Mar 2017 12:25 #12118 by Chris73
Replied by Chris73 on topic 3D Printed Models
Really clever technology, you can print very intricate shapes with them, makes prototyping new products a much quicker process
We have one at work, I wonder if I could print a 40% Extra :whistle:
18 Mar 2017 18:35 #12294 by Chris001
Replied by Chris001 on topic 3D Printed Models
Hi David,
I headed over to the designers website and I can see the temptation, for the cost, providing you have a printer, it's amazing. I've only seen one 3D printed item, it was an antenna mount, and although it's doing the job fine, it's not what I'd call 'refined', this I'm guessing is down to the resolution of the printer not the design. There is no doubt that 3D printed items will become increasingly common and I assume like the early days of inkjet printers the quality will go up and the price will come down.
Has anyone played with a 3D printer? And how easy is it to design something in 3D space and then get that printed.
  • ronp849
19 Mar 2017 13:48 - 19 Mar 2017 13:50 #12312 by ronp849
Replied by ronp849 on topic 3D Printed Models
Hi All
I have Franks 3D printer which I have just managed to get working after a rebuild, (managed to print a servo mount). I just wondered if anyone would be interested in seeing it working :unsure: at a club meeting. Is there Broadband at the meeting hall? There are loads of free samples that can be downloaded.
Printing is not quick - the simple servo mount took about 20mins so it would need to be started and left to run. Watching it do its thing can be likened to drying paint but it is also quite theraputic.
Ron
Last edit: 19 Mar 2017 13:50 by ronp849.
19 Mar 2017 15:06 #12313 by Chris001
Hi Ron, I'd be interested to see it work.
Did you design your own servo mount? And how strong is it, i.e. could you use a 3D printer to make a control horn or servo arm?
All the best, Chris
  • ronp849
19 Mar 2017 16:25 - 19 Mar 2017 16:39 #12319 by ronp849
Hi Chris
I downloaded the file from www.thingiverse.com/thing:272930 It is much stronger than I expected and it even has the servo mounting screw holes included.
Checkout the thingiverse website, www.thingiverse.com/categories for stacks of printable items.
There are CAD packages available and some are free. The learning curve is pretty steep and I am not even on the ladder yet!!
I suspect it wont be long before you will be able to download almost anything without having to design it yourself. The file could be for a full size object with as much detail as possible. The printer software would allow you to scale it down to whatever size you required.
ie:
Fully detailed cockpit.
Fully detailed Pilot.
Fully operational, (Sliding or opening) cockpit canopies, (PET material).
Metal 3D printing is available as are tabletop filament extruders. (A sudden demand for scrap plastic on the horizon!!)
The possibilities are endless.
Ron
Last edit: 19 Mar 2017 16:39 by ronp849.
19 Mar 2017 22:26 #12322 by Chris001
Hi Ron,
I believe the possibilities are going to be quite significant, but that is in part if you are able to design what you want, otherwise you're at the mercy of other peoples designs. To that end I've been playing with a 2D and 3D CAD package for the last month, trying to do a little each evening, mostly tutorials but a bit of my own designing too.
It's a steep learning curve, and maybe in the end it will be beyond me. I'm still not sure where 3D printing is going to go, at the moment the quality, from what I've seen, is fine for prototyping and items that don't need a refined aesthetic quality, i.e. my antenna mounts. But as stepper motors and control units are coming down in price I've got an eye towards CNC hot wire cutting and CNC routing/milling. But before any of that I need to learn to design, and then understand the work flow from design to product, so nothing is going to be happening any time soon.
How fine a resolution can your 3D printer print, 0.1mm?
All the best, Chris
06 Apr 2017 07:49 - 06 Apr 2017 07:50 #12513 by DaveBright
Replied by DaveBright on topic 3D Printed Models
DavidTappin wrote: Whatever next?
3D printed turbofan -edf with reverse thrust!
Last edit: 06 Apr 2017 07:50 by DaveBright.
Time to create page: 0.660 seconds
