Superwing MkXII
06 Dec 2017 15:39 #14883 by Phil Ford
Replied by Phil Ford on topic Superwing MkXII
Colin, how far back from front of wing did you put the hook for bungy launch? I would assume it should be just forward of the CG?
06 Dec 2017 16:39 #14884 by 4Pedalsfly
Replied by 4Pedalsfly on topic Superwing MkXII
PhilF51 wrote: Colin, how far back from front of wing did you put the hook for bungy launch? I would assume it should be just forward of the CG?
Phil - Hook is 142mm back from the leading edge, C of G is 200mm so 58 mm in front of c of G.
In that position it is very stable off the bungee / ramp..
I glued a piece of 1/8 the ply 1 in Square into the foam using p.v.a glue & screwed the hook into it.
Best of luck with the maiden flight.
