Phase 6 Glider KIt
01 Feb 2018 11:40 #15594 by kevinross
Replied by kevinross on topic Phase 6 Glider KIt
David
It looks like you have mounted the wing plate plus the elevator pushrod much lower in the fuselage compared with mine.. Must be very tight between the torque rods and the wing bolt.
However,with so many slim wing servos on the market today, it makes sense to have twin servos, then like mine its possible program an air brake mix.
01 Feb 2018 12:43 #15597 by Phil Ford
Replied by Phil Ford on topic Phase 6 Glider KIt
kevinross wrote: However,with so many slim wing servos on the market today, it makes sense to have twin servos, then like mine its possible program an air brake mix.
My thoughts exactly Kevin. ;)
01 Feb 2018 19:15 #15607 by Dave Rogers
Replied by Dave Rogers on topic Phase 6 Glider KIt
My wing is like David’s. One servo in centre. Easy peasy.
02 Feb 2018 15:11 - 02 Feb 2018 15:23 #15625 by Phil Ford
Chris, have took all the Bits out of the box. Wings veneered and cut out centrally for a mini servo. (Although they still supply the torque rod and nylon bearings for centre servo, although the central recess is longer there. Torque rod is now recommended to use for optional flaps. Fuselage sides are two piece still and CNC cut using liteply. :( Might follow what others have done that I read recently and that is make up one piece sides in birch ply using the original sides as a template. Fuselage formers are laser cut ply and no longer require balsa backing.
Last edit: 02 Feb 2018 15:23 by Phil Ford.
02 Feb 2018 18:25 #15631 by AlanF
Replied by AlanF on topic Phase 6 Glider KIt
Dave Rogers wrote: My wing is like David’s. One servo in centre. Easy peasy.
Dave, I can't remember, was yours the fully symmetrical wing version?
03 Feb 2018 17:06 #15643 by Dave Rogers
Yes fully symmetrical. Also my wing does have 2 servos but both mounted one behind the other in the centre of the wing
03 Feb 2018 17:20 #15644 by AlanF
Cheers Dave, yours flew well enough the other week, that's the one I would be tempted with.
03 Feb 2018 18:06 - 03 Feb 2018 18:07 #15645 by Phil Ford
Dave Rogers wrote: Yes fully symmetrical. Also my wing does have 2 servos but both mounted one behind the other in the centre of the wing
That must be tight fit. You have full length ailerons? I'll have to look at that. :huh:
Last edit: 03 Feb 2018 18:07 by Phil Ford.
03 Feb 2018 19:01 #15646 by JonTappin
Replied by JonTappin on topic Phase 6 Glider KIt
AlanF wrote: Cheers Dave, yours flew well enough the other week, that's the one I would be tempted with.
I've had both versions in the past Alan, the Pro version does fly better for aerobatics but does need good lift conditions. The semi symetrical sport version will stay up better in light lift and still flies very well.
03 Feb 2018 20:04 #15647 by AlanF
The current plan is: in light winds fly power at Cashmoor then when the wind picks up head for the slopes. With that in mind the pro version would probably be ok. The truth is I'm torn between a Phase 6, building a Phase 5 or going for a 60"" Wildthing.
Time to create page: 0.338 seconds
